HBase Link Parameters
Updated on 2024-10-24 GMT+08:00
CDM supports the following HBase data sources:
MRS HBase
When connecting CDM to HBase of MRS, configure the parameters as described in Table 1.
  • MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported.
  • Before creating an MRS link, you need to add an authenticated Kerberos user on MRS and log in to the MRS management page to change the initial password. Then use the new user to create an MRS link.
  • To connect to an MRS 2.x cluster, create a CDM cluster of version 2.x first. CDM 1.8.x clusters cannot connect to MRS 2.x clusters.
  • If the connection fails after you select a cluster, check whether the MRS cluster can communicate with the CDM instance which functions as the agent. They can communicate with each other in the following scenarios:
    • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in different regions, a public network or a dedicated connection is required. If the Internet is used for communication, ensure that an EIP has been bound to the CDM cluster, and the MRS cluster can access the Internet and the port has been enabled in the firewall rule.
    • If the CDM cluster in the DataArts Studio instance and the MRS cluster are in the same region, VPC, subnet, and security group, they can communicate with each other by default. If they are in the same VPC but in different subnets or security groups, you must configure routing rules and security group rules. For details about how to configure routing rules, see Configuring Routing Rules. For details about how to configure security group rules, see Configuring Security Group Rules.
    • The MRS cluster and the DataArts Studio workspace belong to the same enterprise project. If they do not, you can modify the enterprise project of the workspace.
    If an agent is connected to multiple MRS clusters and one of the MRS clusters is deleted or abnormal, connections to the other MRS clusters will be affected. Therefore, you are advised to connect an agent to only one MRS cluster.
Table 1 MRS HBase link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
mrs_hbase_link
Manager IP
Floating IP address of MRS Manager. Click Select next to the Manager IP text box to select an MRS cluster. CDM automatically fills in the authentication information.
DataArts Studio does not support MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2, and only supports MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1.
127.0.0.1
Username
If Authentication Method is set to KERBEROS, you must provide the username and password used for logging in to MRS Manager. If you need to create a snapshot when exporting a directory from HDFS, the user configured here must have the administrator permission on HDFS.
To create a data connection for an MRS security cluster, do not use user admin. The admin user is the default management page user and cannot be used as the authentication user of the security cluster. You can create an MRS user and set Username and Password to the username and password of the created MRS user when creating an MRS data connection.
  • If the CDM cluster version is 2.9.0 or later and the MRS cluster version is 3.1.0 or later, the created user must have the permissions of the Manager_viewer role to create links on CDM. To perform operations on databases, tables, and columns of an MRS component, you also need to add the database, table, and column permissions of the MRS component to the user by following the instructions in the MRS documentation.
  • If the CDM cluster version is earlier than 2.9.0 or the MRS cluster version is earlier than 3.1.0, the created user must have the permissions of Manager_administrator or System_administrator to create links on CDM.
  • A user with only the Manager_tenant or Manager_auditor permission cannot create connections.
cdm
Password
Password used for logging in to MRS Manager
Authentication method used for accessing the cluster:
  • SIMPLE: Select this for non-security mode.
  • KERBEROS: Select this for security mode.
SIMPLE
HBase Version
HBase version
HBASE_2_X
Run Mode
Run mode of the HBase link. This parameter is used only when the HBase version is HBASE_2_X.
  • EMBEDDED: The link instance runs with CDM. This mode delivers better performance.
  • Standalone: The link instance runs in an independent process. If CDM needs to connect to multiple Hadoop data sources (MRS, Hadoop, or CloudTable) with both Kerberos and Simple authentication modes, Standalone prevails.
    Note: The STANDALONE mode is used to solve the version conflict problem. If the connector versions of the source and destination ends of the same link are different, a JAR file conflict occurs. In this case, you need to place the source or destination end in the STANDALONE process to prevent the migration failure caused by the conflict.
STANDALONE
Use Cluster Config
You can create cluster configurations on the Links page to simplify the configuration of Hadoop link parameters.
No
Cluster Config Name
This parameter is valid only when Use Cluster Config is set to Yes. Select a cluster configuration that has been created.
For details about how to configure a cluster, see Managing Cluster Configurations.
hbase_01
Click Show Advanced Attributes, and then click Add to add configuration attributes of other clients. The name and value of each attribute must be configured. You can click Delete to delete no longer used attributes.
FusionInsight HBase
When connecting CDM to HBase of FusionInsight HD, configure the parameters as described in Table 2.
Table 2 FusionInsight HBase link parameters
Example Value
Name
FI_hbase_link
Manager IP
IP address of FusionInsight Manager
127.0.0.1
Manager Port
Port number of FusionInsight Manager
28443
CAS Server Port
Port number of the CAS server used to connect to FusionInsight
20009
Username
Username used for logging in to FusionInsight Manager.
cdm
Password
Password used for logging in to FusionInsight Manager
Kerberos
HBase Version
HBase version
HBASE_2_X
Run Mode
STANDALONE
Use Cluster Config
You can use the cluster configuration to simplify parameter settings for the Hadoop connection.
No
Cluster Config Name
hbase_01
Apache HBase
When connecting CDM to HBase of Apache Hadoop, configure the parameters as described in Table 3.
Table 3 Apache HBase link parameters
Example Value
Name
hadoop_hbase_link
ZK Link
ZooKeeper link of HBase
Format: <host1>:<port>,<host2>:<port>,<host3>:<port>
zk1.example.com:2181,zk2.example.com:2181,zk3.example.com:2181
Kerberos
IP and Host Name Mapping
IP address and host name.
If the configuration file uses host names, configure the mappings between all IP addresses and hosts. Use spaces to separate hosts.
IP: 10.3.6.9
Host name: hostname01
HBase Version
HBase version
HBASE_2_X
Run Mode
STANDALONE
Use Cluster Config
No
Cluster Config Name
hbase_01
