Creating an Entire Database Migration Job
CDM supports entire DB migration between homogeneous and heterogeneous data sources. The migration principles are the same as those in Table/File Migration Jobs. Each type of Elasticsearch, each key prefix of Redis, or each collection of MongoDB can be executed concurrently as a subtask.
Each time an entire DB migration job is executed, its subtasks are recreated based on the configuration of the migration job. You cannot modify the subtasks and then run the migration job again.
Supported Data Sources lists the data sources supporting entire database migration.
Field names of the source and destination parameters cannot contain ampersands (&) or number signs (%).
- A link has been created. For details, see Creating a Link Between CDM and a Data Source.
- The CDM cluster can communicate with the data source.
- Log in to the management console and choose Service List > Cloud Data Migration. In the left navigation pane, choose Cluster Management. Locate the target cluster and click Job Management.
- Choose
. The page for configuring the job is displayed.Figure 1 Creating an entire DB migration job
- Configure the related parameters of the source database according to Table 1.
Table 1 Parameter description Source Database
Example Value
- DWS
- MySQL
- PostgreSQL
- SQL Server
- Oracle
- SAP HANA
Schema/Tablespace
Name of the schema or tablespace from which data will be extracted. This parameter is displayed when Use SQL Statement is set to No. Click the icon next to the text box to go to the page for selecting a schema or directly enter a schema or tablespace.
If the desired schema or tablespace is not displayed, check whether the login account has the permissions required to query metadata.
schema
WHERE Clause
WHERE clause used to specify the tables to be extracted. This parameter applies to all subtables in the entire DB migration. If this parameter is not set, the entire table is extracted. If the table to be migrated does not contain the fields specified by the WHERE clause, the migration will fail.
You can set a date macro variable to extract data generated on a specific date. For details, see Incremental Migration of Relational Databases.
age > 18 and age <= 60
Null in Partition Column
Whether a partition field can be null
Yes
Hive
Database Name
Name of the database to be migrated. The user configured in the source link must have the permission to read the database.
hivedb
HBase
CloudTable
Start Time
Start time (included). The format is yyyy-MM-dd hh:mm:ss. The dateformat time macro variable function is supported.
Examples: 2017-12-31 20:00:00, ${dateformat(yyyy-MM-dd, -1, DAY)} 02:00:00, and ${dateformat(yyyy-MM-dd HH:mm:ss, -1, DAY)}
"2017-12-31 20:00:00"
End Time
End time (excluded) The format is yyyy-MM-dd hh:mm:ss. The dateformat time macro variable function is supported.
Examples: 2018-01-01 20:00:00, ${dateformat(yyyy-MM-dd, -1, DAY)} 02:00:00, and ${dateformat(yyyy-MM-dd HH:mm:ss, -1, DAY)}
"2018-01-01 20:00:00"
Redis
Key Filter Character
Filter character used to determine the keys to be migrated
For example, if the value of this parameter is a*, all asterisks (*) will be migrated.
a*
DDS
Database Name
Name of the database from which data is to be migrated. The user configured in the source link must have the permission to read the database.
ddsdb
Query Filter
Filter used to match documents.
Example: {HTTPStatusCode:{$gt:"400",$lt:"500"},HTTPMethod:"GET"}
- Configure the related parameters, from Table 2, for the destination cloud service.
Table 2 Destination job parameters Destination Database
Example Value
- RDS for MySQL
- RDS for PostgreSQL
- RDS for SQL Server
For details about the destination job parameters required for entire DB migration to an RDS database, see To MySQL/SQL Server/PostgreSQL.
schema
DWS
For details about the destination job parameters required for entire DB migration to DWS, see To DWS.
MRS Hive
For details about the destination job parameters required for entire DB migration to MRS HIVE, see To Hive.
hivedb
MRS HBase
CloudTable
For details about the destination job parameters required for entire DB migration to MRS HBase or CloudTable, see To HBase/CloudTable.
Yes
Redis
Clear Database
Clears the database data before data import.
Yes
DDS
Database Name
mongodb
Migration Behavior
Select Add or Replace.
- If you are migrating an entire relational database, click Next after configuring job parameters to select source and destination tables. Ensure that the destination table names are the same as the source table names. For example, if the source table name is test, the destination table name must also be test.
Figure 2 Field mapping
- Click Next and set job parameters.
Figure 3 Task parametersTable 3 describes related parameters.
Table 3 Task configuration parameters Parameter
Example Value
Concurrent Tables
Number of tables to be concurrently executed
3
Concurrent Extractors
Maximum number of threads of the job for reading data from the source
The number of concurrent threads may be less than or equal to the value of this parameter for some data sources that do not support concurrent extraction, for example, CSS and ClickHouse.
Write Dirty Data
Whether to record dirty data. By default, this parameter is set to No.
Yes
Write Dirty Data Link
This parameter is only displayed when Write Dirty Data is set to Yes.
Only links to OBS support dirty data writes.
obs_link
OBS Bucket
This parameter is only displayed when Write Dirty Data Link is a link to OBS.
Name of the OBS bucket to which the dirty data will be written.
dirtydata
Dirty Data Directory
Directory for storing dirty data on OBS. Dirty data is saved only when this parameter is configured.
You can go to this directory to query data that fails to be processed or is filtered out during job execution, and check the source data that does not meet conversion or cleaning rules.
/user/dirtydir
Max. Error Records in a Single Shard
When the number of error records of a single map exceeds the upper limit, the job will automatically terminate and the imported data cannot be rolled back. You are advised to use a temporary table as the destination table. After the data is imported, rename the table or combine it into the final data table.
0
- Click Save or Save and Run.
When the job starts running, a sub-job will be generated for each table. You can click the job name to view the sub-job list.
During the migration of an entire Oracle database to Hudi, if you select a view or a table that has no primary key at the source, automatic table creation is not supported.
