On this page
Show all
To MySQL/SQL Server/PostgreSQL
Updated on 2024-10-24 GMT+08:00
Table 1 lists the destination job parameters when the destination link is an MySQL, SQL Server, or PostgreSQL link.
Table 1 Parameter description
Category
Example Value
Basic parameters
Schema/Tablespace
Name of the database to which data will be written. The schema can be automatically created. Click the icon next to the text box to select a schema or tablespace.
schema
Auto Table Creation
This parameter is displayed only when the source is a relational database. The options are as follows:
  • Non-auto creation: CDM will not automatically create a table.
  • Auto creation: If the destination database does not contain the table specified by Table Name, CDM will automatically create the table. If the table specified by Table Name already exists, no table is created and data is written to the existing table.
  • Deletion before creation: CDM deletes the table specified by Table Name, and then creates the table again.
Non-auto creation
Table Name
Name of the table to which data will be written. Click the icon next to the text box. The dialog box for selecting the table is displayed.
This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development jobOffset) rather than (Actual start time of the CDM jobOffset).
table
Clear Data Before Import
Whether to clear the data in the destination table before data import. The options are as follows:
  • Do not clear: The data in the destination table is not cleared before data import. The imported data is just added to the table.
  • Clear all data: All data is cleared from the destination table before data import.
  • Clear part of data: Part of the data in the destination table is cleared before data import. If you select Clear part of data, you must configure WHERE Clause to specify which part will be deleted.
Clear part of data
WHERE Clause
If Clear Data Before Import is set to Clear part of data, data in the destination table will be deleted based on the WHERE clause after the configuration is complete and before the import starts.
age > 18 and age <= 60
Constraint Conflict Handling
How to handle data conflicts when data is being imported to RDS for MySQL
  • insert into: When a primary key or unique index conflict occurs, data cannot be written and will become dirty data.
  • replace into: When a primary key or unique index conflict occurs, the original row is deleted and a new row is inserted to replace all the fields in the original row.
  • on duplicate key update: When a primary key or unique index conflict occurs in a row in the destination table, the data columns except the unique constraint column in this row are updated.
insert into
Advanced parameters
Import to Staging Table
If you set this parameter to Yes, the transaction mode is enabled. CDM automatically creates a temporary table and imports data to the temporary table. After the data is imported successfully, it is migrated to the destination table in transaction mode. If the import fails, the destination table is rolled back to the state before the job starts. For details, see Migration in Transaction Mode.
The default value is No, indicating that CDM directly imports the data to the destination table. In this case, if the job fails to be executed, the data that has been imported to the destination table will not be rolled back automatically.
If you select Clear part of data or Clear all data for Clear Data Before Import, CDM does not roll back the deleted data in transaction mode.
No
Extend Field Length
When Auto creation is selected, the length of the character fields can be extended to three times the original length and then written to the destination table. If the encoding types of the source and destination databases are different, but the character fields in the source and destination tables are the same, errors may occur during data migration due to character length difference.
When this function is enabled, some fields consume three times the storage space of the user.
No
Use NOT NULL Constraint
If you choose to create a target table automatically and specify the NOT NULL constraint, keep the NOT NULL constraints of the source and target tables consistent.
Yes
Prepare for Data Import
The SQL statement that is first executed before a task is executed. Currently, only one SQL statement can be executed in wizard mode.
create temp table
Complete Statement After Data Import
The SQL statement that is executed after a task is executed. Currently, only one SQL statement can be executed.
merge into
Loader Threads
Number of threads started in each loader. A larger number allows more concurrent write operations.
This parameter is unavailable if Constraint Conflict Handling is set to replace into or on duplicate key update.
