On this page
Show all
From HDFS
Updated on 2024-10-24 GMT+08:00
If the source link of a job is an HDFS link, that is, if data is exported from MRS HDFS, FusionInsight HDFS, or Apache HDFS, configure the source job parameters based on Table 1.
Table 1 Parameter description
Category
Example Value
Basic parameters
Source Link Name
Select a type from the drop-down list box.
hdfs_to_cdm
Source Directory/File
This parameter is available only when Pull List File is set to No.
Directory or file path from which data will be extracted.
Directory from which data is to be migrated. All files (including all nested subdirectories and their subfiles) in the directory will be migrated.
This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development jobOffset) rather than (Actual start time of the CDM jobOffset).
/user/cdm/
File Format
File format used when transferring data. The options are as follows:
  • CSV: Source files will be migrated to tables after being converted to CSV format.
  • Binary: Files (even not in binary format) will be transferred directly. It is used for file copy.
  • Parquet: Source files will be migrated to tables after being converted to Parquet format.
CSV
Pull List File
This parameter is displayed only when File Format is set to Binary.
If the pull list file function is enabled, the content of a file (such as a .txt file) in an OBS bucket can be read as the list of files to be migrated. The content in the file must be the absolute path of the file to be migrated (rather than a directory). The following is example content:
/mrs/job-properties/application_1634891604621_0014/job.properties
/mrs/job-properties/application_1634891604621_0029/job.properties
Yes
OBS Link of List File
This parameter is available only when Pull List File is set to Yes. You can select the OBS link where the list file is located.
OBS_test_link
OBS Bucket of entries files
This parameter is available only when Pull List File is set to Yes. It indicates the name of the OBS bucket where the list file is located.
01
Path/Directory of entries files
This parameter is available only when Pull List File is set to Yes. It indicates the absolute path or directory of the list file in the OBS bucket.
/0521/Lists.txt
Advanced attributes
Line Separator
Lind feed character in a file. By default, the system automatically identifies \n, \r, and \r\n. This parameter is displayed only when File Format is set to CSV.
\n
Field Delimiter
Character used to separate fields in the file. To set the Tab key as the delimiter, set this parameter to \t. This parameter is displayed only when File Format is set to CSV.
Use First Row as Header
This parameter is displayed only when File Format is set to CSV. When you migrate a CSV file to a table, CDM writes all data to the table by default. If you set this parameter to Yes, CDM uses the first N rows of the CSV file as the heading row and does not write the row to the destination table.
No
Encoding Type
Encoding type, for example, UTF-8 or GBK. You can set the encoding type for text files only. This parameter is invalid when File Format is set to Binary.
GBK
Start Job by Marker File
Whether to start a job by a marker file. A job is only started if there is a marker file for starting the job in the source path. If there is no marker file, the job will be suspended for a period of time specified by Suspension Period.
ok.txt
Filter Type
Only paths or files that meet the filtering conditions are transferred. The options are None, Wildcard, and Regex. For details, see Incremental File Migration.
Directory Filter
If you set Filter Type to Wildcard or Regex, enter a wildcard character to filter paths. The paths that meet the filtering condition are migrated. You can configure multiple paths separated by commas (,).
*input
File Filter
If you set Filter Type to Wildcard or Regex, you can enter a wildcard character to search for files in a specified path. The files that meet the search criteria are migrated. You can configure multiple files separated by commas (,).
*.csv
Time Filter
If you select Yes, files are transferred based on their modification time.
Yes
Minimum Timestamp
If you set Filter Type to Time Filter, and specify a point in time for this parameter, only the files modified at or after the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss.
This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss,-90,DAY))} indicates that only files generated within the latest 90 days are migrated.
2019-07-01 00:00:00
Maximum Timestamp
If you set Filter Type to Time Filter, and specify a point in time for this parameter, only the files modified before the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss.
This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss))} indicates that only the files whose modification time is earlier than the current time are migrated.
2019-07-30 00:00:00
Create Snapshot
If you set this parameter to Yes, CDM creates a snapshot for the source directory to be migrated (the snapshot cannot be created for a single file) before it reads files from HDFS. Then CDM migrates the data in the snapshot.
Only the HDFS administrator can create a snapshot. After the CDM job is completed, the snapshot is deleted.
No
Encryption
If the source data is encrypted, CDM can decrypt the data before exporting it. Select whether to decrypt the source data and select a decryption algorithm. The options are as follows:
  • NONE: Export data without decrypting it.
  • AES-256-GCM: The AES 256-bit encryption algorithm is used to encrypt data. Currently, only the AES-256-GCM (NoPadding) encryption algorithm is supported. This parameter is used for encryption at the migration destination and decryption at the migration source.
For details, see Encryption and Decryption During File Migration.
AES-256-GCM
DEK
This parameter is displayed only when Encryption is set to AES-256-GCM. The key consists of 64 hexadecimal numbers and must be the same as the DEK configured during encryption. If the encryption and decryption keys are inconsistent, the system does not report an exception, but the decrypted data is incorrect.
DD0AE00DFECD78BF051BCFDA25BD4E320DB0A7AC75A1F3FC3D3C56A457DCDC1B
IV
This parameter is displayed only when Encryption is set to AES-256-GCM. The initialization vector consists of 32 hexadecimal numbers and must be the same as the IV configured during encryption. If the encryption and decryption keys are inconsistent, the system does not report an exception, but the decrypted data is incorrect.
5C91687BA886EDCD12ACBC3FF19A3C3F
MD5 File Extension
This parameter is used to check whether the files extracted by CDM are consistent with source files. For details, see MD5 Verification.
.md5
