Updated on 2026-10-10 GMT+08:00
Viewing the Application Progress
This topic describes how to view the approval progress of the certificate application.
You can perform operations based on the prompt in the application progress to obtain the certificate as soon as possible.
  • You have purchased a certificate.
  • You have submitted a certificate application to the CA.
  1. Log in to the CCM console.
  2. In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
  3. View the certificate application progress in the Status/Application Progress column of the certificate. Figure 1 shows an example.
    Figure 1 Viewing the Application Progress
    Perform operations based on the certificate status. The following are examples of some important operations:
    • Pending application: You have not submitted the certificate application to the corresponding CA. You need to submit it manually. For details, see Submitting an Official Certificate Application.
    • Pending domain name verification: You have submitted the certificate application to the CA but have not completed domain name ownership verification. You need to validate domain name ownership as instructed by the CA. For details, see Verifying Domain Name Ownership.
    • Pending organization verification: For an OV or EV certificate, the CA will further validate your organization identity after domain name ownership verification. For more details, see Verifying the Organization (OV and EV).
    • To be issued: You have completed operations, such as domain name ownership verification and organization verification. The CA will issue the certificate after it has validated your verification, which takes some while.
    After all information is verified, the certificate status changes to Issued.
