- What's New
- Function Overview
Product Bulletin
- [January 23, 2025] CAs Suspend OV and EV SSL Certificate Approval and Issuance During the Spring Festival
- [December 24, 2024] CA Venders Suspend Certificate Issuance During Christmas and New Year's Day
- [October 28, 2024] Notice on Switching the DigiCert Root Certificate
- [July 29, 2024] Notice on DigiCert and GeoTrust SSL Certificate Price Changes
- [October 8, 2023] Validity Period Change of Test Certificates
- [April 17, 2023] Changing GeoTrust DV to RapidSSL DV
- [Feb 8, 2023] Notice on DigiCert Root Certificate Update
- [December 16, 2022] DigiCert and GeoTrust Suspend OV and EV Certificate Validation During Christmas Holidays
- [September 13, 2022] SSL Certificate Chains Embedded in Applications May Cause Communication Failures
- [July 25, 2022] Organization Unit (OU) Field Removed from SSL Certificates
- [March 23, 2022] SSL Certificate Manager Entry Will Be Changed on March 25, 2022
- [Product Notices] Huawei Cloud SCM Domain Ownership Verification Policy (File-based Verification) Changed on Nov 12, 2021
- [August 20, 2020] Notice on the Change of the Maximum Validity Period of SSL Certificates
- [August 14, 2020] Notice on Delaying Issuance of EV and EV Pro Certificates Due to the DigiCert System Failure
- [July 27, 2020] CAs Will No Longer Issue Two-Year SSL Certificates
- [July 27, 2020] Notice on Revocation of DV Certificates by CAs
- [July 19, 2020] DigiCert System Maintenance Notice
- [May 31, 2020] GlobalSign System Maintenance Notice
- [May 3, 2020] DigiCert System Maintenance Notice
- [April 26, 2020] Symantec Certificate Brand Change Notice
- Billing
- Getting Started
SSL Certificate Manager (SCM) User Guide
- About SCM and SSL Certificate Usage
- Purchasing an SSL Certificate
- Applying for an SSL Certificate
Installing an SSL Certificate
Installing an SSL Certificate on a Web Server
- Downloading an SSL Certificate
- Downloading a Root Certificate
- Installing an SSL Certificate on a Tomcat Server
- Installing an SSL Certificate on an Nginx Server
- Installing an SSL Certificate on an Apache Server
- Installing an SSL Certificate on an IIS Server
- Installing an SSL Certificate on a WebLogic Server
- Installing an SSL Certificate on a Resin Server
- Deploying an SSL Certificate to Other Huawei Cloud Products
Managing SSL Certificates
- Reissuing an SSL Certificate
- Unsubscribing from an SSL Certificate
- Renewing an SSL Certificate
- Revoking an SSL Certificate
- Re-applying for a Revoked SSL Certificate
- Deleting an SSL Certificate from CCM
- Uploading an External Certificate to SCM
- Adding an Additional Domain Name
- Withdrawing an SSL Certificate Application
- Canceling Authorization for Privacy Information
- Pushing an SSL Certificate to Other Cloud Services
- Viewing Details About an SSL Certificate
- Viewing the Application Progress
- CSRs
- Sharing
- Managing Tags
- Permissions Management
- Private Certificate Authority (PCA) User Guide
Best Practices
- CCM Best Practice Summary
- Best Practices for SSL Certificate Manager
- Best Practices for Private Certificate Management
API Reference
- Before You Start
- Calling APIs
- API Overview
- API Description
- Examples
Historical APIs
SCM APIs
- Querying the Certificate List
- Querying Details of a Certificate
- Modifying a Certificate
- Querying the Product Type of a Certificate
- Querying the Product Details of a Certificate
- Applying for a Certificate
- Verifying a CSR
- Saving Certificate Information
- Reading the Information Entered When Applying for a Certificate
- Canceling an Application
- Deleting a Certificate
- Uploading Authentication Information
- Downloading a Certificate
- Uploading a Certificate
- Revoking a Certificate
- Pushing a Certificate
- Querying Push Records
- Querying Domain Name Verification Information
SCM APIs
- Appendix
- Change History
- SDK Reference
Certificate Consulting
- What Are the Differences Between SSL Certificate Manager and Private Certificate Authority?
- Which Websites Require HTTPS?
- What Are the Differences Between HTTPS and HTTP?
- What Is a Public Key and a Private Key?
- What Are the Relationships Between a Public Key, Private Key, and Digital Certificate?
- Why Is a Non-Password-Protected Private Key Required?
- What Are Mainstream Formats of Digital Certificates?
- What Information Does an SSL Certificate Contain?
- Can I Use SSL Certificates for Other Regions, Accounts, or Platforms?
- Can I Use an Unused SSL Certificate Anytime I Want?
- Can SSL Certificates Be Upgraded?
- Does the SSL Certificate Have Restrictions on the Server Port?
- Why Is SCM Inaccessible or the Operation Button Grayed Out When I Access the SCM Console?
- Regions and AZs
SSL Certificate Application and Purchase
- SSL Certificate Selection
About Required Domain Name Details
- How Do I Enter a Domain Name for a Certificate When Applying for an SSL Certificate?
- What Are the Differences Between a Single-Domain Name, Multi-Domain Name, and Wildcard-Domain Name in SCM?
- What Is the Relationship Between a Domain Name and an SSL Certificate?
- What Domains Can Wildcard-Domain Certificates Support?
- What Domain Name Should I Use to Apply for an SSL Certificate?
- Can I Change the Primary Domain Name Associated with a Certificate?
- Does the Relationship Between the Primary Domain Name and Additional Domain Name Have Any Impact on Domain Names?
- How Do I Make a CSR File?
- What Are the Differences Between the CSR Generated by the System and the CSR Made by Yourself?
- How Do I Export a CSR File?
- Domain-related Concepts
- Problems Related to Domains
- About Required Information
Troubleshooting
- What Can I Do If I Encounter a Problem When Purchasing, Applying for, Installing, or Using a Free SSL Certificate?
- What Can I Do If the Submit Button Is Unavailable?
- Can I Change Certificate Information After I Submit a Certificate Application?
- What Can I Do If I Encounter a Problem During SSL Certificate Application?
- About Test Certificates
Domain Name Ownership Verification
- How Do I Verify Domain Ownership?
- How Do I Verify the Domain Ownership Manually by DNS?
- How Do I Perform Verification by File?
- How Do I Perform Verification by Email?
- How Do I Check Whether Domain Name Verification Takes Effect?
- How Can I Check Whether DNS Verification Takes Effect for Windows OSs?
- What Can I Do If Domain Ownership Verification Does Not Take Effect?
- How Do I Query a Domain Name Provider?
- How Do I Query and Verify the Email Address of the Domain Administrator?
- How Do I Use DNS to Verify Domains Not Hosted on Huawei Cloud?
- Why Does the SSL Certificate Remain in the Pending Domain Name Verification State (Application Progress Is 40%) After Domain Name Verification Is Complete?
- How Do I Change the Domain Name Verification Mode When the SSL Certificate Status Is Pending domain name verification?
- What Do I Do If DNS Verification for a DV Certificate Fails?
- How Long Does It Take to Approve an SSL Certificate?
- Why Does the Certificate Stay in the CA Verifying Status for a Long Time?
- What Can I Do After I Submit an SSL Certificate Application?
- How Do I Handle the Email or Phone Call from the CA?
- Do I Need to Get a Newly Purchased SSL Certificate Approved?
- What Can I Do When I Fail to Pass the Security Review?
- What Can I Do When a Message Indicating Approval Failure Due to Blank Main Domain Name Is Displayed?
SSL Certificate Download, Installation, and Use
- SSL Certificate Download
SSL Certificate Installation
- On Which Servers Can an SSL Certificate Be Deployed?
- How Do I Install an SSL Certificate on a Server?
- How Do I Check Whether the Deployed SSL Certificate Takes Effect?
- Is the Original SSL Certificate Still Available After a Server IP Address Is Changed?
- In Which Geographical Locations Can an SSL Certificate Be Used?
- How Do I Add an SSL Certificate to the Background of a Website Built by Baota?
- How Do I Solve Problems Related to SSL Certificate Installation or Use?
SSL Certificate Use
- How Do I Configure a Non-Huawei Cloud SSL Certificate for a Huawei Cloud Product?
- How Do I Apply an SSL Certificate to Other Huawei Cloud Services?
- Which Region Will a Certificate Be Deployed to When I Deploy an SSL Certificate in CCM to Other Cloud Product?
- Is HTTPS Automatically Enabled After an SSL Certificate Is Deployed to a Cloud Product?
- How Do I Solve the Problem That Occurs When I Use Certificates in WAF, ELB, or CDN?
- Why Is a Message Indicating that the Certificate Chain Is Incomplete Displayed When I Configure HTTPS on CDN?
- Why Is an Error Reported When I Deploy an SSL Certificate with an Uploaded CSR to WAF, ELB, or CDN?
- How Do I Use an SSL Certificate After It Is Issued?
- What Can I Do If My SSL Certificate Cannot Be Deployed to Other Services?
- Issues Related to SSL Certificate Uploading
- What Can I Do If Errors Are Reported When I Upload an SSL Certificate?
SSL Certificate Troubleshooting
- What Can I Do If the Browser Displays a Message Indicating that the SSL Certificate Is Untrusted?
- Why Does the Browser Still Consider the Website Insecure While the Website Has an SSL Certificate Deployed?
- Why Is My Website Inaccessible by Domain Name After an SSL Certificate Is Installed?
- Why Does the HTTPS Access Speed Become Slower After an SSL Certificate Is Installed?
- Why Does the Browser Prompt a Not Secure Warning to Visitors After I Configure an SSL Certificate for the Website?
- What Can I Do If the Browser Displays "Your Connection Is Not a Private Connection"?
- Will the Browser Prompt A Warning Indicating the Deployed SSL Certificate Is Not Secure?
Certificate Validity Period
- What Can I Do If My SSL Certificate Expired?
- How Long Is an SSL Certificate Valid?
- What Can I Do If an SSL Certificate Is About to Expire?
- How Long Does an SSL Certificate Take Effect After Being Purchased?
- Validity Periods and Replacement of the Current and New SSL Certificates
- How Can I Renew an SSL Certificate?
- How Do I Configure a Certificate Expiration Notification?
- Will Services Be Affected If an SSL Certificate Is Not Updated After It Expires?
- Validity Periods of Private Certificates
- How Long Will an Order Become Invalid If I Do Not Apply for a Certificate After Purchasing It?
- How Do I Know When My Certificate Expires?
- About Billing, Renewal, and Unsubscription
SSL Certificate Management
- What Are the Differences Between Revoking a Certificate and Deleting a Certificate?
- Can I Withdraw a Certificate Revocation or Deletion Application?
- How Do I Convert a Certificate into the PEM Format?
- How Do I Complete the Certificate File When Uploading a Certificate?
- How Do I Configure a Certificate Chain?
- Why Is the SSL Certificate Not Displayed in the Certificate List?
- How Long Does It Take to Revoke a Certificate?
- Troubleshooting
- About Certificate Use
- Videos
More Documents
- Overview of Private Certificate Application
- Private CA Management
- Applying for a Private Certificate
- Downloading a Private Certificate
Installing a Private Certificate
- Trusting a Private Root CA
- Installing a Private Certificate on a Client
Installing a Private Certificate on a Server
- Installing a Private Certificate on a Tomcat Server
- Installing a Private Certificate on an Nginx Server
- Installing a Private Certificate on an Apache Server
- Installing a Private Certificate on an IIS Server
- Installing a Private Certificate on a WebLogic Server
- Installing a Private Certificate on a Resin Server
- Revoking a Private Certificate
- Viewing Details of a Private Certificate
- Deleting a Private Certificate
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Cloud Certificate Manager/
SSL Certificate Manager (SCM) User Guide/
Installing an SSL Certificate/
