Monitoring Overview
Monitoring Center is a next-generation O&M platform developed by Huawei Cloud for cloud native containers. It monitors applications and resources in real time, collects metrics and events to analyze application health statuses, and visualizes multi-dimensional data. Compatible with mainstream open-source components, Monitoring Center supports quick fault locating.
CCI 2.0 supports pod resource monitoring with multiple metrics, such as metrics for CPU, memory, disk, and network. Pods have built-in system agents, which provide pod and container metrics over HTTP. The agents are integrated into pods and occupy resources in the pods. You are advised to reserve 30-MiB memory.
Function Introduction
- Multi-dimensional data insights: CCI container monitoring is supported. There are metrics for CPU, memory, network, and containers. The health and load of CCI can be comprehensively monitored. You can view basic pod metrics on the CCI console or AOM console. For details, see Basic Metrics for Pod Resource Monitoring.
- Dashboard: You can query metrics using PromQL on the AOM dashboard. The dashboard can aggregate different charts on the same screen and display resource data in different forms, such as line charts and number charts, so you can obtain comprehensive and in-depth monitoring data.
Table 1 describes basic metrics for resources such as CPU, memory, and disk.
| Category | Metric Name | Definition |
| CPU | container_cpu_system_seconds_total | Cumulative system CPU time, in seconds |
| container_cpu_usage_seconds_total | Total CPU time (system CPU time and user CPU time), in seconds | |
| container_cpu_user_seconds_total | Cumulative user CPU time, in seconds | |
| container_cpu_cfs_periods_total | Number of elapsed enforcement period intervals | |
| container_cpu_cfs_throttled_periods_total | Number of throttled period intervals | |
| container_cpu_cfs_throttled_seconds_total | Total time a container has been throttled | |
| File system or disk | container_fs_inodes_free | Number of available inodes in a file system |
| container_fs_usage_bytes | Amount of file system storage used by a container | |
| container_fs_inodes_total | Number of inodes in a file system | |
| container_fs_io_current | Number of I/Os currently in progress in a disk or file system | |
| container_fs_io_time_seconds_total | Cumulative seconds spent on doing I/Os by a disk or file system | |
| container_fs_io_time_weighted_seconds_total | Cumulative weighted I/O time of a disk or file system | |
| container_fs_limit_bytes | Total disk or file system capacity that can be consumed by a container | |
| container_fs_reads_bytes_total | Cumulative amount of disk or file system data read by a container | |
| container_fs_read_seconds_total | Cumulative count of seconds a container spent on reading disk or file system data | |
| container_fs_reads_merged_total | Cumulative count of merged disk or file system reads made by a container | |
| container_fs_reads_total | Cumulative count of disk or file system reads completed by a container | |
| container_fs_sector_reads_total | Cumulative count of sector reads completed by a container in a disk or file system | |
| container_fs_sector_writes_total | Cumulative count of sector writes completed by a container to a disk or file system | |
| container_fs_writes_bytes_total | Total amount of data written by a container to a disk or file system | |
| container_fs_write_seconds_total | Cumulative count of seconds a container spent on writing data to a disk or file system | |
| container_fs_writes_merged_total | Cumulative count of merged container writes to a disk or file system | |
| container_fs_writes_total | Cumulative count of completed container writes to a disk or file system | |
| container_blkio_device_usage_total | Bytes used by I/O (blkio) on block devices | |
| Memory | container_memory_failures_total | Cumulative number of container memory allocation failures |
| container_memory_failcnt | Number of memory usage limit hits | |
| container_memory_cache | Total page cache memory | |
| container_memory_mapped_file | Size of memory mapped files | |
| container_memory_max_usage_bytes | Maximum memory usage recorded for a container, in bytes | |
| container_memory_rss | Size of the resident memory set for a container | |
| container_memory_swap | Container swap usage | |
| container_memory_usage_bytes | Current memory usage of a container, in bytes | |
| container_memory_working_set_bytes | Current working set of a container, in bytes | |
| Network | container_network_receive_bytes_total | Total volume of data received by the container network, in bytes |
| container_network_receive_errors_total | Cumulative number of errors encountered while receiving data | |
| container_network_receive_packets_dropped_total | Cumulative number of packets dropped while receiving data | |
| container_network_receive_packets_total | Cumulative number of packets received | |
| container_network_transmit_bytes_total | Total volume of data transmitted over the container network, in bytes | |
| container_network_transmit_errors_total | Cumulative number of errors encountered while transmitting data | |
| container_network_transmit_packets_dropped_total | Cumulative number of packets dropped while transmitting data | |
| container_network_transmit_packets_total | Cumulative number of packets transmitted | |
| Container spec or status | container_processes | Number of processes running inside a container |
| container_sockets | Number of open sockets for a container | |
| container_file_descriptors | Number of open file descriptors for a container | |
| container_threads | Number of threads running inside a container | |
| container_threads_max | Maximum number of threads allowed inside a container | |
| container_ulimits_soft | Soft ulimit value of process 1 in a container. Process resources are unlimited if the value is -1, except priority and nice. | |
| container_spec_cpu_period | CPU period of a container | |
| container_spec_cpu_shares | CPU share of a container | |
| container_spec_cpu_quota | CPU quota of a container | |
| container_spec_memory_limit_bytes | Memory limit for a container | |
| container_spec_memory_reservation_limit_bytes | Memory reservation limit for a container | |
| container_spec_memory_swap_limit_bytes | Memory swap limit for a container | |
| container_start_time_seconds | Start time of a container | |
| container_last_seen | Last time a container was seen by the exporter | |
| Object status | kube_pod_info | Information about a pod |
| kube_pod_owner | Information about the pod's owner | |
| kube_pod_container_resource_limits | Container resource limits | |
| kube_replicaset_owner | Information about the ReplicaSet's owner |
