Collecting Logs Using a Sidecar Container
You can use hostpath-replacement to replace hostPath with emptyDir supported by CCI, inject a sidecar container to collect logs through pod-sidecars, and mount the standard output logs to the sidecar container through mount-stdlog-containers.
You have configured the sidecar container by referring to Configuring a Sidecar Container (Dynamic Injection).
volume.cci.io/mount-stdlog-containers and volume.cci.io/mount-stdlog-containers-path cannot be configured at the same time.
Using a YAML File
apiVersion: apps/v1
kind: Deployment
labels:
version: v1
bursting.cci.io/burst-to-cci: enforce
namespace: default
replicas: 1
selector:
matchLabels:
app: deploy-example
version: v1
template:
annotations:
bursting.cci.io/hostpath-replacement: '[{"name":"log","policyType":"replaceByEmptyDir","emptyDir":{"sizeLimit":"10Gi"}}]'
bursting.cci.io/pod-sidecars: '{"containers":[{"name":"log-sidecar","image":"fluent-bit:latest","resources":{},"volumeMounts":[{"name":"log","mountPath":"/tmp/log"}],"position":"tail"}]}'
volume.cci.io/mount-stdlog-containers: log-sidecar # Name of the container whose standard output logs are to be mounted
labels:
app: deploy-example
version: v1
containers:
- image: nginx:latest
resources:
limits:
cpu: "1"
memory: 2Gi
requests:
cpu: "1"
memory: 2Gi
volumeMounts:
- mountPath: /tmp/log
imagePullSecrets:
- name: default-secret
volumes:
- hostPath:
path: /local/log
name: log With the preceding configurations, the sidecar container can collect two types of logs:
- Standard output logs. The sidecar container can collect the standard output logs of service containers as files and store these standard output logs to the /var/log/pods directory.
- File logs. Service containers output log files to the emptyDir volume shared with the sidecar container, which then collects the files from the volume.
| Annotation | Type | Description | Example Value |
| volume.cci.io/mount-stdlog-containers | String |
| Example 1: "container-0,container-1" Example 2: "*" |
| volume.cci.io/mount-stdlog-containers-path | String |
| Example 1: "{\"container-0\":\"/var/log/pods\",\"container-1\":\"/tmp/log/pods\"}" Example 2: "{\"*\":\"/tmp/log/pods\"}" |
