The CCE Cloud Bursting Engine for CCI add-on can be used with CCI 1.0 and CCI 2.0. When it is used to scale pods to CCI 2.0, the metrics-server add-on cannot collect metrics of these pods. As a result, the HPA may not work normally. To ensure that the HPA works normally, replace the metrics-server add-on with the Cloud Native Cluster Monitoring add-on.
- Install the Cloud Native Cluster Monitoring add-on.
- Log in to the CCE console.
 - Click the name of the target CCE cluster to go to the cluster console.
 - In the navigation pane, choose Add-ons.
 - Select the Cloud Native Cluster Monitoring add-on and click Install.
       Figure 1 Installing the Cloud Native Cluster Monitoring add-on
        - Local Data Storage must be enabled for Data Storage Configuration.
 - Click Install.
 - Install the Cloud Native Cluster Monitoring add-on for monitoring.
- If the Kubernetes Metrics Server add-on is not installed in the CCE cluster, enable the Metric API. For details, see Providing Basic Resource Metrics Through the Metrics API. After the configuration is complete, Prometheus is used to collect system resource metrics.
 - If the Kubernetes Metrics Server add-on has been installed in the CCE cluster, use either of the following methods to enable the Metric API:
- Method 1: Uninstall the Kubernetes Metrics Server add-on and enable the Metric API.
 - Select the Kubernetes Metrics Server add-on and click Uninstall.
 - Enable the Metric API. For details, see Providing Basic Resource Metrics Through the Metrics API. After the configuration is complete, Prometheus is used to collect system resource metrics.
 - Method 2: Modify the APIService object.
Configuration for updating the APIService object v1beta1.metrics.k8s.io:
apiVersion: apiregistration.k8s.io/v1 kind: APIService metadata: labels: app: custom-metrics-apiserver release: cceaddon-prometheus name: v1beta1.metrics.k8s.io spec: group: metrics.k8s.io groupPriorityMinimum: 100 insecureSkipTLSVerify: true service: name: custom-metrics-apiserver namespace: monitoring port: 443 version: v1beta1 versionPriority: 100You can save the object as a file, name it metrics-apiservice.yaml, and run the following command:
kubectl apply -f metrics-apiservice.yaml
Run the kubectl top pod -n monitoring command. If the following information is displayed, the Metrics API can be accessed:
# kubectl top pod -n monitoring NAME CPU(cores) MEMORY(bytes) ...... custom-metrics-apiserver-d4f556ff9-l2j2m 38m 44Mi ......
          To uninstall the add-on, run the following kubectl command and delete the APIService object first or the add-on cannot be installed due to residual APIService resources.
kubectl delete APIService v1beta1.metrics.k8s.io
 - Create an HPA policy.
 - In the navigation pane, choose Policies.
 - Click the Scaling Policies tab.
 - In the right corner, click Create HPA Policy.
 - Configure the policy as needed. For example, to increase the CPU usage of a pod, you configure a CPU usage rule, and you can see that the HPA policy scales out the workload.
