- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
- Best Practices
Developer Guide
- Overview
- Using Native kubectl (Recommended)
- Namespace and Network
- Pod
- Label
- Deployment
- EIPPool
- EIP
- Pod Resource Monitoring Metric
- Collecting Pod Logs
- Managing Network Access Through Service and Ingress
- Using PersistentVolumeClaim to Apply for Persistent Storage
- ConfigMap and Secret
- Creating a Workload Using Job and Cron Job
- YAML Syntax
API Reference
- Before You Start
- Calling APIs
- Getting Started
- Proprietary APIs
Kubernetes APIs
- ConfigMap
- Pod
- StorageClass
- Service
Deployment
- Querying All Deployments
- Deleting All Deployments in a Namespace
- Querying Deployments in a Namespace
- Creating a Deployment
- Deleting a Deployment
- Querying a Deployment
- Updating a Deployment
- Replacing a Deployment
- Querying the Scaling Operation of a Specified Deployment
- Updating the Scaling Operation of a Specified Deployment
- Replacing the Scaling Operation of a Specified Deployment
- Querying the Status of a Deployment
- Ingress
- OpenAPIv2
- VolcanoJob
- Namespace
- ClusterRole
- Secret
- Endpoint
- ResourceQuota
- CronJob
API groups
- Querying API Versions
- Querying All APIs of v1
- Querying an APIGroupList
- Querying APIGroup (/apis/apps)
- Querying APIs of apps/v1
- Querying an APIGroup (/apis/batch)
- Querying an APIGroup (/apis/batch.volcano.sh)
- Querying All APIs of batch.volcano.sh/v1alpha1
- Querying All APIs of batch/v1
- Querying All APIs of batch/v1beta1
- Querying an APIGroup (/apis/crd.yangtse.cni)
- Querying All APIs of crd.yangtse.cni/v1
- Querying an APIGroup (/apis/extensions)
- Querying All APIs of extensions/v1beta1
- Querying an APIGroup (/apis/metrics.k8s.io)
- Querying All APIs of metrics.k8s.io/v1beta1
- Querying an APIGroup (/apis/networking.cci.io)
- Querying All APIs of networking.cci.io/v1beta1
- Querying an APIGroup (/apis/rbac.authorization.k8s.io)
- Querying All APIs of rbac.authorization.k8s.io/v1
- Event
- PersistentVolumeClaim
- RoleBinding
- StatefulSet
- Job
- ReplicaSet
- Data Structure
- Appendix
- Out-of-Date APIs
- Change History
- Product Consulting
Basic Concept FAQs
- What Is CCI?
- What Are the Differences Between Cloud Container Instance and Cloud Container Engine?
- What Is an Environment Variable?
- What Is a Service?
- What Is Mcore?
- What Are the Relationships Between Images, Containers, and Workloads?
- What Are Kata Containers?
- Can kubectl Be Used to Manage Container Instances?
- What Are Core-Hours in CCI Resource Packages?
- Workload Abnormalities
Container Workload FAQs
- Why Service Performance Does Not Meet the Expectation?
- How Do I Set the Quantity of Instances (Pods)?
- How Do I Check My Resource Quotas?
- How Do I Set Probes for a Workload?
- How Do I Configure an Auto Scaling Policy?
- What Do I Do If the Workload Created from the sample Image Fails to Run?
- How Do I View Pods After I Call the API to Delete a Deployment?
- Why an Error Is Reported When a GPU-Related Operation Is Performed on the Container Entered by Using exec?
- Can I Start a Container in Privileged Mode When Running the systemctl Command in a Container in a CCI Cluster?
- Why Does the Intel oneAPI Toolkit Fail to Run VASP Tasks Occasionally?
- Why Are Pods Evicted?
- Why Is the Workload Web-Terminal Not Displayed on the Console?
- Why Are Fees Continuously Deducted After I Delete a Workload?
Image Repository FAQs
- Can I Export Public Images?
- How Do I Create a Container Image?
- How Do I Upload Images?
- Does CCI Provide Base Container Images for Download?
- Does CCI Administrator Have the Permission to Upload Image Packages?
- What Permissions Are Required for Uploading Image Packages for CCI?
- What Do I Do If Authentication Is Required During Image Push?
Network Management FAQs
- How Do I View the VPC CIDR Block?
- Does CCI Support Load Balancing?
- How Do I Configure the DNS Service on CCI?
- Does CCI Support InfiniBand (IB) Networks?
- How Do I Access a Container from a Public Network?
- How Do I Access a Public Network from a Container?
- What Do I Do If Access to a Workload from a Public Network Fails?
- What Do I Do If Error 504 Is Reported When I Access a Workload?
- What Do I Do If the Connection Timed Out?
- Storage Management FAQs
- Log Collection
- Account
- SDK Reference
- Videos
Overview
When the bursting add-on is used to schedule workloads to CCI 2.0, the Kubernetes Metrics Server add-on cannot collect metric data of these pods, which may affect the HPA. You can use the Cloud Native Cluster Monitoring add-on to replace Kubernetes Metrics Server add-on to ensure that HPA functions properly.
- Install the Cloud Native Cluster Monitoring add-on.
- Log in to the CCE console.
- Click the name of the target CCE cluster to go to the cluster console.
- In the navigation pane, choose Add-ons.
- Select the Cloud Native Cluster Monitoring add-on and click Install.
Figure 1 Installing the Cloud Native Cluster Monitoring add-on
- Configure the specifications (Deployment Mode to Server mode).
To use HPA in Agent mode, contact technical support.
- Install the Cloud Native Cluster Monitoring add-on for monitoring.
- If the Kubernetes Metrics Server add-on is not installed in the CCE cluster, enable the Metric API. For details, see Providing Resource Metrics Through the Metrics API. After the configuration is complete, Prometheus is used to collect system resource metrics.
- If the Kubernetes Metrics Server add-on has been installed in the CCE cluster, use either of the following methods to enable the Metric API:
- Method 1: Uninstall the Kubernetes Metrics Server add-on and enable the Metric API.
- Select the Kubernetes Metrics Server add-on and click Uninstall.
- Enable the Metric API. For details, see Providing Resource Metrics Through the Metrics API. After the configuration is complete, Prometheus is used to collect system resource metrics.
- Method 2: Modify the APIService object.
Configuration for updating the APIService object v1beta1.metrics.k8s.io:
apiVersion: apiregistration.k8s.io/v1 kind: APIService metadata: labels: app: custom-metrics-apiserver release: cceaddon-prometheus name: v1beta1.metrics.k8s.io spec: group: metrics.k8s.io groupPriorityMinimum: 100 insecureSkipTLSVerify: true service: name: custom-metrics-apiserver namespace: monitoring port: 443 version: v1beta1 versionPriority: 100
You can save the object as a file, name it metrics-apiservice.yaml, and run the following command:
kubectl apply -f metrics-apiservice.yaml
Run the kubectl top pod -n monitoring command. If the following information is displayed, the Metrics API can be accessed:
# kubectl top pod -n monitoring NAME CPU(cores) MEMORY(bytes) ...... custom-metrics-apiserver-d4f556ff9-l2j2m 38m 44Mi ......
NOTICE:
To uninstall the add-on, run the following kubectl command and delete the APIService object first or the add-on cannot be installed due to residual APIService resources.
kubectl delete APIService v1beta1.metrics.k8s.io
