Updated on 2026-02-11 GMT+08:00
Logging
Overview
After workloads are scheduled to CCI, you can use the Cloud Native Log Collection add-on to collect pod logs, improving workload observability. This section describes how to enable logging for the workloads scheduled to CCI.
By default, for workloads scaled to CCI, container stdout logs will be collected and reported to AOM. AOM provides 500-MB free log storage space for each account each month. If the log storage space exceeds 500 MB, you will be billed based on the actual usage. For details about pricing, see Product Pricing Details.
To disable container stdout log collection, specify log.stdoutcollection.kubernetes.io: '{"collectionContainers": []}' in the pod annotation. The following is an example:
kind: Deployment
apiVersion: apps/v1
  namespace: default
  replicas: 1
  template:
      annotations:
      containers:
        - name: container-1
          image: nginx:latest
Log Collection Reliability
The log system's main purpose is to record all stages of data for service components, including startup, initialization, exit, runtime details, and exceptions. It is primarily employed in O&M scenarios for tasks like checking component status and analyzing fault causes.
Standard streams (stdout and stderr) and local log files use non-persistent storage. However, data integrity may be compromised due to the following risks:
  • Log rotation and compression potentially deleting old files
  • Temporary storage volumes being cleared when Kubernetes pods end
  • Automatic OS cleanup triggered by limited node storage space
While the Cloud Native Log Collection add-on employs techniques like multi-level buffering, priority queues, and resumable uploads to enhance log collection reliability, logs could still be lost in the following situations:
  • The service log throughput surpasses the collector's processing capacity.
  • The service pod is terminated and immediately reclaimed by the container runtime.
  • The log collector pod experiences exceptions.
The following lists some recommended best practices for cloud native log management. You can review and implement them thoughtfully.
  • Use dedicated, high-reliable streams to record critical service data (for example, financial transactions) and store the data in persistent storage.
  • Avoid storing sensitive information like customer details, payment credentials, and session tokens in logs.
Application Scenario
How to Use
CCE and CCI container logs need to be collected.
You can collect the following three types of logs:
  • Container standard output: stderr and stdout logs of a specified container in a cluster
  • Container file logs: file logs in a specified container in a cluster
  • Node file logs: file logs from a specified node path in a cluster
NOTICE:
Only container file logs can be collected for pods scheduled to CCI.
Types of logs that cannot be collected
  • Logs of soft link paths in containers
  • Logs from specified directories such as the system, device, cgroup, and tmpfs directories
A pod scheduled to CCI has multiple log collection policies associated.
To better collect logs, reserve the required amount of memory for the pod. Associate the pod with the first log collection policy and reserve at least 50 MiB of memory. Reserve 5 MiB of memory each time an additional log collection policy is associated.
Ultra-long logs need to be collected.
A log larger than 250 KB cannot be collected.
Log file name
By default, the audit.log, oss.icAgent.trace, oss.script.trace, and audit_*.log files are not collected. Do not use these names for the logs.
The log file name is too long.
Logs whose file name length exceeds 190 bytes cannot be collected. For log files whose names contain 180 to 190 bytes, only the first file can be collected.
Log collection rate
For each pod, no more than 10,000 single-line logs can be collected per second, and no more than 2,000 multiple-line logs can be collected per second.
Maximum number of collected files
In a single pod, no more than 2,000 log files can be collected by all log collection policies.
Log collection before a container is stopped
When a container is stopped, if log collection is delayed due to network latency or high resource usage, some logs generated before the container is stopped may be lost.
  1. Install two add-ons: CCE Cloud Bursting Engine for CCI and Cloud Native Log Collection.
    1. Log in to the CCE console.
    2. Click the name of the target CCE cluster to go to the cluster console.
    3. In the navigation pane, choose Add-ons.
    4. Select the CCE Cloud Bursting Engine for CCI add-on and click Install.
    5. Enable the Networking option.
    6. On the Add-ons page, select the Cloud Native Log Collection add-on and click Install.
  2. Create a workload on the CCE console.
    1. In the navigation pane, choose Workloads.
    2. Click Create Workload. For details, see Creating a Workload.
    3. Configure the parameters. For details, see Scheduling Pods to CCI.
  3. Create a log collection policy.
    1. In the navigation pane, choose Logging.
    2. Click View Log Collection Policies. On the displayed page, click Create Log Collection Policy.
    3. Configure the parameters and click OK.
      Workloads scheduled to CCI do not support hot update of log policies. After a log collection policy is updated, redeploy the pods to apply the modification.
  4. View the YAML file of the pod that is scheduled to CCI.
    To collect CCI pod logs, the Cloud Native Log Collection add-on injects the following annotations to the pod.
    Annotation
    Example Value
    coordinator.cci.io/inject-volumes
    '[{"name":"log-agent-conf","configMap":{"name":"log-agent-cci-logging-config","defaultMode":384},"namespace":"monitoring"},{"name":"log-agent-cert","secret":{"secretName":"log-agent-ca-secret","defaultMode":384},"namespace":"monitoring"}]'
    logconf.k8s.io/fluent-bit-configmap-reference
    monitoring-log-agent-cci-logging-config
    logconfigs.logging.openvessel.io
    '{"testcci001":{"container_files":{"container-1":"/var/test/*/*.log"},"regulation":""}}''
    sandbox-volume.openvessel.io/volume-names
    log-agent-conf,log-agent-cert
  5. View the reported logs in Logging.
    For details about logging, see Cloud Native Log Collection.
