- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
- Best Practices
Developer Guide
- Overview
- Using Native kubectl (Recommended)
- Namespace and Network
- Pod
- Label
- Deployment
- EIPPool
- EIP
- Pod Resource Monitoring Metric
- Collecting Pod Logs
- Managing Network Access Through Service and Ingress
- Using PersistentVolumeClaim to Apply for Persistent Storage
- ConfigMap and Secret
- Creating a Workload Using Job and Cron Job
- YAML Syntax
API Reference
- Before You Start
- Calling APIs
- Getting Started
- Proprietary APIs
Kubernetes APIs
- ConfigMap
- Pod
- StorageClass
- Service
Deployment
- Querying All Deployments
- Deleting All Deployments in a Namespace
- Querying Deployments in a Namespace
- Creating a Deployment
- Deleting a Deployment
- Querying a Deployment
- Updating a Deployment
- Replacing a Deployment
- Querying the Scaling Operation of a Specified Deployment
- Updating the Scaling Operation of a Specified Deployment
- Replacing the Scaling Operation of a Specified Deployment
- Querying the Status of a Deployment
- Ingress
- OpenAPIv2
- VolcanoJob
- Namespace
- ClusterRole
- Secret
- Endpoint
- ResourceQuota
- CronJob
API groups
- Querying API Versions
- Querying All APIs of v1
- Querying an APIGroupList
- Querying APIGroup (/apis/apps)
- Querying APIs of apps/v1
- Querying an APIGroup (/apis/batch)
- Querying an APIGroup (/apis/batch.volcano.sh)
- Querying All APIs of batch.volcano.sh/v1alpha1
- Querying All APIs of batch/v1
- Querying All APIs of batch/v1beta1
- Querying an APIGroup (/apis/crd.yangtse.cni)
- Querying All APIs of crd.yangtse.cni/v1
- Querying an APIGroup (/apis/extensions)
- Querying All APIs of extensions/v1beta1
- Querying an APIGroup (/apis/metrics.k8s.io)
- Querying All APIs of metrics.k8s.io/v1beta1
- Querying an APIGroup (/apis/networking.cci.io)
- Querying All APIs of networking.cci.io/v1beta1
- Querying an APIGroup (/apis/rbac.authorization.k8s.io)
- Querying All APIs of rbac.authorization.k8s.io/v1
- Event
- PersistentVolumeClaim
- RoleBinding
- StatefulSet
- Job
- ReplicaSet
- Data Structure
- Appendix
- Out-of-Date APIs
- Change History
- Product Consulting
Basic Concept FAQs
- What Is CCI?
- What Are the Differences Between Cloud Container Instance and Cloud Container Engine?
- What Is an Environment Variable?
- What Is a Service?
- What Is Mcore?
- What Are the Relationships Between Images, Containers, and Workloads?
- What Are Kata Containers?
- Can kubectl Be Used to Manage Container Instances?
- What Are Core-Hours in CCI Resource Packages?
- Workload Abnormalities
Container Workload FAQs
- Why Service Performance Does Not Meet the Expectation?
- How Do I Set the Quantity of Instances (Pods)?
- How Do I Check My Resource Quotas?
- How Do I Set Probes for a Workload?
- How Do I Configure an Auto Scaling Policy?
- What Do I Do If the Workload Created from the sample Image Fails to Run?
- How Do I View Pods After I Call the API to Delete a Deployment?
- Why an Error Is Reported When a GPU-Related Operation Is Performed on the Container Entered by Using exec?
- Can I Start a Container in Privileged Mode When Running the systemctl Command in a Container in a CCI Cluster?
- Why Does the Intel oneAPI Toolkit Fail to Run VASP Tasks Occasionally?
- Why Are Pods Evicted?
- Why Is the Workload Web-Terminal Not Displayed on the Console?
- Why Are Fees Continuously Deducted After I Delete a Workload?
Image Repository FAQs
- Can I Export Public Images?
- How Do I Create a Container Image?
- How Do I Upload Images?
- Does CCI Provide Base Container Images for Download?
- Does CCI Administrator Have the Permission to Upload Image Packages?
- What Permissions Are Required for Uploading Image Packages for CCI?
- What Do I Do If Authentication Is Required During Image Push?
Network Management FAQs
- How Do I View the VPC CIDR Block?
- Does CCI Support Load Balancing?
- How Do I Configure the DNS Service on CCI?
- Does CCI Support InfiniBand (IB) Networks?
- How Do I Access a Container from a Public Network?
- How Do I Access a Public Network from a Container?
- What Do I Do If Access to a Workload from a Public Network Fails?
- What Do I Do If Error 504 Is Reported When I Access a Workload?
- What Do I Do If the Connection Timed Out?
- Storage Management FAQs
- Log Collection
- Account
- SDK Reference
- Videos
Environment Configuration
Logging In to the CCI Console
Log in to the CCI console and grant CCI the permission to access other cloud services.
- Click
in the upper left corner and select a region.
CCI is available only in regions LA-Sao Paulo 1, AP-Bangkok, and AP-Singapore.
CCI does not allow you to create resources in sub-projects.
- Switch to the CCI console.
- If this is the first time you are logging in to the CCI console, click Agree to grant CCI the permission to access other cloud services.
After the permission is granted, an agency named cci_admin_trust is created. You can view the agency on the IAM console.
(Optional) Uploading Images
The cloud platform provides the SoftWare Repository for Container (SWR) service for you to upload container images to the image repository. You can easily pull these images when creating workloads on CCI. For details about how to upload images, see Uploading an Image Through a Container Engine Client.
Currently, CCI does not support third-party image repositories.
After Enterprise Management is enabled, if an IAM user needs to use private images in your account, you need to log in to the CCI console using the account, choose Image Repository, and grant the required permission to the user on the SWR console.
You can use either of the following methods to grant permission to an IAM user:
- On the details page of an image, click the Permissions tab, click Add Permission, and then grant the read, write, or manage permission to the user. For details, see Granting Permissions for a Specific Image.
- On the details page of an organization, click the Users tab, click Add Permission, and then grant the read, write, or manage permission to the user. For details, see Granting Permissions for an Organization.
(Optional) Creating a Load Balancer
A load balancer allows your workloads to be accessed from external networks. For details about how to create a load balancer, see Creating a Load Balancer.
- Choose Service List > Networking > Elastic Load Balance.
- On the Elastic Load Balance page, click Buy Elastic Load Balancer.
Specify the required parameters to create a load balancer.
A load balancer can work on a public or private network.
(Optional) Preparing SSL Certificates
CCI allows workloads to be accessed over HTTPS. You can specify your own SSL certificate when you create a workload.
SSL certificates are classified into authoritative and self-signed certificates. Authoritative certificates are issued by CAs. You can obtain authoritative certificates from third-party certificate agents. A client trusts websites that use authoritative certificates by default. Self-signed certificates are self-issued by users, typically using OpenSSL. By default, self-signed certificates are untrusted by the client. The browser will display an alarm message when you access a website that uses a self-signed certificate. You can continue to access the website by ignoring the alarm.
For details about SSL certificates, see SSL Certificates.
