Updated on 2025-04-27 GMT+08:00
Kubernetes 1.15 (EOM) Release Notes
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. This section describes the updates in CCE Kubernetes 1.15.
To enable interoperability from one Kubernetes installation to the next, you must upgrade your Kubernetes clusters before the maintenance period ends.
CCE provides full-link component optimization and upgrade for Kubernetes v1.15, which includes two minor versions v1.15.11 and v1.15.6-r1.
Resource Changes and Deprecations
  • Ingress in the extensions/v1beta1 API version has been deprecated. It will be no longer served from Kubernetes 1.19. You can use the networking.k8s.io/v1beta1 API version.
  • NetworkPolicy in the extensions/v1beta1 API version will be officially suspended in 1.16. Migrate to use the networking.k8s.io/v1 API version.
  • PodSecurityPolicy in the extensions/v1beta1 API version will be officially suspended in 1.16. Migrate to use the policy/v1beta1 API version.
  • DaemonSets, Deployments, and ReplicaSets in the extensions/v1beta1, apps/v1beta1, and apps/v1beta2 API versions will not be served in 1.16. You can use the apps/v1 API version.
  • PriorityClass is upgraded to scheduling.k8s.io/v1, scheduling.k8s.io/v1beta1, and scheduling.k8s.io/v1alpha1. It will be deprecated in 1.17.
  • The series.state field in the events.k8s.io/v1beta1 Event API version has been deprecated and will be removed from 1.18.
