Updated on 2026-08-13 GMT+08:00
Node Pool Upgrade
When CCE releases a new OS image or updates node pool configurations, existing nodes cannot be automatically upgraded. You must upgrade them manually. If no new OS image or configuration update is available, the node pool requires no action, and the message "All OS nodes are up to date" is displayed.
Upgrading a Node Pool
The upgrade methods for default node pools and non-default node pools are different.
  • This section describes how to upgrade an OS by resetting the target node. Workloads running on a node may be interrupted due to standalone deployment or insufficient schedulable resources. Evaluate the upgrade risks and perform the upgrade during off-peak hours. Alternatively, specify a disruption budget for your key applications to ensure the availability of these applications during the upgrade.
  • The system disk and data disks of the node will be cleared. Back up important data before resetting a node.
  • Resetting a node will clear your configured Kubernetes labels and taints. As a result, resources (such as local storage and load of specified scheduling nodes) associated with the node may be unavailable. Exercise caution when performing this operation to avoid impact on running services.
  • After the OS is upgraded, the node automatically starts.
  • To ensure node stability, CCE will reserve some CPU and memory resources to run necessary system components.
  • Nodes running private images cannot be upgraded.
  • Compatibility issues may occur when the node OS of an early version is upgraded. In this case, manually reset the node for the OS upgrade.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Cluster Upgrade in the navigation pane. In the right pane, click the Node Pool Upgrade tab.
  3. Click Upgrade in the Operation column of the default node pool.
  4. In the displayed Operating System Upgrade window, configure parameters.
    • Target Operating System: shows the image of the target version. You do not need to configure this parameter.
    • Upgrade Policy: Node Reset is supported.
    • Max. Nodes for Batch Upgrade: maximum number of nodes that will be unavailable during node upgrade. Nodes will be unavailable during synchronization by resetting the nodes. Properly configure this parameter to prevent pod scheduling failures caused by too many unavailable nodes in the cluster.
    • View Node: Select the nodes to be upgraded.
    • Login Mode:
      • Password
        The default username is root. Enter the password for logging in to the node and confirm the password.
        Be sure to remember the password as you will need it when you log in to the node.
      • Key Pair
        Select the key pair used to log in to the node. Private key pairs are accessible only to you. Account key pairs are shared with all users in the account.
        A key pair is used for identity authentication when you remotely log in to the node. If no key pair is available, click Create Key Pair. For details about how to create a key pair, see Creating a Key Pair.
      • Image password (supported for ECSs or PMs whose OSs are private images)
        Retain the password of the selected image. To use this option, ensure that you have set a password for the selected image.
    • Pre-installation script:
      Installation script command, in which CJK characters are not allowed. The script command will be Base64-transcoded. The characters in both the pre-installation and post-installation scripts are centrally calculated, and the total number of characters after transcoding cannot exceed 10,240.
      The script will be executed before Kubernetes software is installed. Note that if the script is incorrect, Kubernetes software may fail to be installed.
    • Post-installation script:
      The script will be executed after Kubernetes software is installed, which does not affect the installation. During post-installation script execution, pods can be scheduled normally. However, if the script times out, node installation fails. To prevent pod scheduling on nodes with incomplete script execution, enable the option to schedule pods only after post-installation script completion.
      Do not use the reboot command in the post-installation script to restart the system immediately. Instead, use the shutdown -r 1 command to restart the system with a one-minute delay.
  5. Click OK.
  • Do not delete or reset nodes during batch synchronization. Otherwise, the synchronization of node pool configuration may fail.
  • This operation involves resetting nodes. Workloads running on a node may be interrupted due to standalone deployment or insufficient schedulable resources. Evaluate the upgrade risks and perform the upgrade during off-peak hours. Alternatively, specify a disruption budget for your key applications to ensure the availability of these applications during the upgrade.
  • During configuration synchronization for existing nodes, the nodes will be reset, and the system disks and data disks will be cleared. Back up important data before the synchronization.
  • Only some node pool parameters can be synchronized by resetting nodes. For details, see Updating a Node Pool.
  • If a new OS patch is available in the environment, synchronize the node pool to update the OS.
  3. Click Synchronize in the Operation column of the target node pool.
  4. In the Batch Synchronize window, configure parameters.
    • OS: shows the image of the target version. You do not need to configure this parameter.
    • Synchronization Type: Reset node is supported.
    • Max. Nodes for Batch Synchronization: the maximum number of nodes that can be synchronized simultaneously. Nodes will be unavailable during synchronization when the nodes are reset. Properly configure this parameter to prevent pod scheduling failures caused by too many unavailable nodes in the cluster.
  5. Click OK.
