Help Center/ Cloud Container Engine/ User Guide/ Scheduling/ GPU Scheduling/ GPU Virtualization/ Priority-based Preemptive Scheduling on Virtual GPUs
Updated on 2026-06-16 GMT+08:00
Task priorities (defined by priority classes) represent the relative importance of a task compared to others in a cluster. Priority-based preemptive scheduling on virtual GPUs enables Volcano Scheduler to prioritize high-priority xGPU pods when virtual GPU resources are limited. It ensures that critical services are scheduled reliably by proactively evicting lower-priority pods when necessary. Once sufficient resources become available, the evicted lower-priority pods are rescheduled. Additionally, this function supports resource preemption in the following dimensions:
  • Single-device resource preemption (supported by default): allows high-priority tasks to preempt resources of the same type on the same GPU. For example, a high-priority memory isolation task can reclaim memory from a lower-priority memory isolation task running on the same GPU.
  • Cross-GPU resource preemption (with topology-aware preemption enabled): allows high-priority tasks to preempt resources used by the same or different types of tasks on different GPUs. For example, a high-priority compute-memory isolation task can preempt memory from a low-priority memory isolation task on another GPU. This enables more flexible, efficient scheduling of GPU resources.
The scheduling process involves the following steps for each pod of a workload to be scheduled:
  1. Obtain candidate nodes. The scheduler identifies nodes that can satisfy the resource requirements of the pods to be scheduled by evicting one or more low-priority pods.
  2. Sort the candidate nodes. Nodes are scored and ranked based on available idle resources and the priorities and number of pods that would need to be evicted.
  3. Schedule pods. The scheduler selects the right node and evicts lower-priority pods from it to make room for the pods to be scheduled.
If all pods of the workload are scheduled, the operation is considered successful. If any pod in the workload cannot be scheduled, the entire scheduling operation is rolled back to maintain cluster consistency.
As shown in Figure 1, workload F to be scheduled runs in three pods. Volcano Scheduler schedules each pod of this workload using this logic until all pods are scheduled onto the right nodes.
Figure 1 Use case of task priority-based preemptive scheduling
  • A CCE standard or Turbo cluster is available, and the cluster version is v1.27 or later.
  • CCE AI Suite (NVIDIA GPU) has been installed in the cluster. For details, see CCE AI Suite (NVIDIA GPU). The add-on version must meet the following requirements:
    • If the cluster version is v1.27, the add-on version must be 2.1.41 or later.
    • If the cluster version is v1.28 or later, the add-on version must be 2.7.57 or later.
  • GPU nodes with virtualization enabled at the cluster or node pool level are available in the cluster. For details, see Preparing Virtual GPU Resources.
  • Volcano Scheduler of 1.18.1 or later has been installed. For details, see Volcano Scheduler.
Notes and Constraints
In an xGPU preemption scenario, only high-priority jobs are allowed to preempt resources for scheduling. However, this strategy does not guarantee the best resource utilization. It may lead to resource fragmentation within the cluster.
After this function is enabled, the Volcano Scheduler supports preemption of different types of resources across GPUs. This means that high-priority tasks can preempt resources of the same or different types of tasks on different GPUs.
  1. Log in to the CCE console and click the cluster name to access the cluster console. The Overview page is displayed.
  2. In the navigation pane, choose Settings. Then, click the Scheduling tab. In the Default Cluster Scheduler area, select Volcano for Default Scheduler and click Try Now in Expert mode.
  3. In the window that slides out from the right, set enable_topology_aware_preemption to true to enable preemption of different types of resources across GPUs.
    descheduler_enable: 'false'
    deschedulingInterval: 10m
    enable_scale_in_score: true
    enable_topology_aware_preemption: true  # Enable topology-aware preemption.
    enable_workload_balancer: false
    oversubscription_method: nodeResource
  4. Click Confirm Settings in the lower right corner. In the displayed dialog box, confirm the modification and click Save.
Assume that there is a node in the cluster and the node has a GPU card with 8 GiB of memory. There are two workloads priority-low-gpu and priority-high-gpu. Both of them request 8 GiB of memory. Initially, priority-low-gpu is deployed in the cluster and consumes all available GPU resources. When priority-high-gpu is deployed, the scheduler detects the priority difference and evicts priority-low-gpu to free up resources. As a result, priority-high-gpu is scheduled and runs successfully, while priority-low-gpu enters a pending state. Once GPU resources become available again, priority-low-gpu is rescheduled.
  1. Use kubectl to access the cluster.
  2. Create a YAML file for a low-priority workload. You can enter a file name as needed. If no priority is specified, the default value is 0.
    vim low-priority.yaml
    Example file content:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: priority-low-gpu
      template:
          labels:
          schedulerName: volcano
          containers:
          - image: <your_image_address>     # Replace it with your image address.
            resources:
              requests:
                cpu: 250m
                memory: 512Mi
                volcano.sh/gpu-mem.128Mi: '64' # Request 8 GiB of memory. It must be the same as the value of limits.volcano.sh/gpu-mem.128Mi.
              limits:
                cpu: 250m
                memory: 512Mi
                volcano.sh/gpu-mem.128Mi: '64' # Request 8 GiB of memory. The value is a multiple of 128 MiB, that is, 64 × 128/1024 = 8.
          imagePullSecrets:
          - name: default-secret
  3. Create the workload.
    kubectl apply -f low-priority.yaml
    If information similar to the following is displayed, the workload has been created:
    deployment.apps/priority-low-gpu created
  4. Check whether the pod has been created.
    kubectl get pod -n default
    If information similar to the following is displayed, the pod has been created, and the GPU memory on the GPU node has been used up:
    NAME                               READY   STATUS    RESTARTS   AGE
    priority-low-gpu-6bdb4d7cb-pmtc2   1/1     Running   0          21s
  5. Create a YAML file for a high-priority workload.
    vim high-priority.yaml
    apiVersion: scheduling.k8s.io/v1  # Create a high-priority priority class. The value is 1000.
    description: high priority
    kind: PriorityClass
    preemptionPolicy: PreemptLowerPriority
    value: 1000        # A larger value indicates a higher priority.
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: priority-high-gpu
      template:
          labels:
          priorityClassName: high-priority  # Use the high-priority priority class.
          containers:
            resources:
              requests:
                cpu: 250m
                memory: 512Mi
                volcano.sh/gpu-core.percentage: '50' # Request 50% of the compute.
              limits:
                cpu: 250m
                memory: 512Mi
          imagePullSecrets:
  6. Create the workload.
    kubectl apply -f high-priority.yaml
    If information similar to the following is displayed, the workload has been created. As the GPU memory is exhausted, the cluster cannot schedule the high-priority workload. In such cases, resource preemption is triggered. The lower-priority pods are evicted to free up resources, allowing high-priority pods to be scheduled. This preemption typically takes approximately 30 seconds.
    deployment.apps/priority-high-gpu created
  7. Check whether the resource preemption is successful.
    If information similar to that shown below is displayed, it indicates that resource preemption is successful. Once sufficient GPU resources become available, the scheduler will reschedule the priority-low-gpu-6bdb4d7cb-pmtc2 pod.
    priority-low-gpu-6bdb4d7cb-pmtc2    1/1     Pending   0          21s
    priority-high-gpu-8adb4d6bd-stka1   1/1     Running   0          21s
