Configuring Cross-Origin Access for LoadBalancer Ingresses
Updated on 2025-01-07 GMT+08:00
The same-origin policy of browsers prevents a web page loaded by one origin from directly requesting resources from another origin in web development. Cross-origin resource sharing (CORS) is a secure solution that allows cross-origin requests.
CORS can be used in the following scenarios:
  • Separated frontend and backend: In web development, frontend applications are often deployed under a domain name (for example, app.example.com), while the backend API service uses a different domain name (for example, api.example.com). This can cause cross-origin resource sharing to be blocked, but CORS can help resolve this issue by allowing the frontend to obtain data from the API service.
  • Third-party service integration: If your website needs to call third-party APIs (for example, the APIs of a map service or social media login platform), configure CORS to enable cross-origin resource sharing.
  • CDN: If your website is using a CDN to provide static resources from a domain name that differs from the primary domain, you can use CORS to load these resources.
  • ELB is necessary for accessing ingresses across different origins. To use cross-origin access, submit a service ticket to request the enabling of ELB cross-origin access.
  • If you enable cross-origin access for a LoadBalancer ingress, you will not be able to enable URL redirection, URL rewriting, or HTTP to HTTPS redirection.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.18-r10 or later
    • v1.25: v1.25.16-r0 or later
    • v1.27: v1.27.16-r0 or later
    • v1.28: v1.28.13-r0 or later
    • v1.29: v1.29.8-r0 or later
    • v1.30: v1.30.4-r0 or later
    • Other clusters of later versions
  • The cluster can be accessed using kubectl. For details, see Connecting to a Cluster Using kubectl.
Notes and Constraints
Using kubectl
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress created using an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.class: performance # Only dedicated load balancers are supported.
        kubernetes.io/elb.cors-allow-origin: 'http://example.com'  # The origin that can be accessed
        kubernetes.io/elb.cors-allow-headers: 'fake-header-1' # The allowed request header
        kubernetes.io/elb.cors-expose-headers: 'fake-header-2' #Response header to be exposed
        kubernetes.io/elb.cors-allow-methods: 'GET,POST' # Allowed HTTP request methods
        kubernetes.io/elb.cors-allow-credentials: 'true' # Credentials can be sent.
        kubernetes.io/elb.cors-max-age: '3600' # Cache duration of a pre-check request
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.id: 3f5906fb-2b07-4e33-b3fe-b095f03d86a6
      rules:
        - host: example.com
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: cce
    Table 1 Annotations for cross-origin access
    Type
    Example Value
    Array[string]
    Specify Access-Control-Allow-Origin for the origin that can be accessed.
    Options:
    • Wildcard (*): indicates that all domain names can be accessed.
    • Domain names: start with http:// or https://. Level-1 wildcard domain names are supported. The format is http(s)://example.com or http(s)://example.com:port, where the port number ranges from 1 to 65535.
      You can enter multiple values by separating them with commas (,).
    Array[string]
    Specify Access-Control-Allow-Headers for allowed request headers. You can enter multiple values by separating them with commas (,).
    Array[string]
    Specify Access-Control-Expose-Headers for custom response headers that can be accessed by a cross-origin request. This allows you to retrieve non-standard response headers using client-side JavaScript code. You can enter multiple values by separating them with commas (,).
    Array[string]
    Specify Access-Control-Allow-Methods for allowed HTTP request methods.
    String
    Specify Access-Control-Allow-Credentials to control the sending of credentials (such as cookies).
    Options:
    • true: Credentials can be sent.
    • false: Credentials cannot be sent.
    Once configured, the settings cannot be deleted. To remove the configuration, use kubernetes.io/elb.cors-disabled to delete all cross-origin settings.
    String
    Specify Access-Control-Max-Age for the cache duration of a CORS pre-check request. Unit: second. Value range: -1 to 172800
    Properly configure this parameter based on service requirements. If the value is too low, pre-check requests may happen frequently. If the value is too high, the CORS policy may not take effect immediately.
    String
    Disable all cross-origin settings. Options:
    • true: disables all cross-origin settings. The parameter values in the YAML file will not be deleted, but all cross-origin settings will not take effect.
    • false: default value, indicating that the cross-origin settings take effect based on your settings.
    kubernetes.io/elb.cors-disabled: 'true'
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
Verifying Cross-Origin Access
  1. Log in to the ELB console, locate the load balancer used by the ingress, and check whether the forwarding policy of the listener contains cross-origin configurations.
  2. Use curl to send a cross-origin request and check the response header.
    curl -X OPTIONS -H 'Origin: {Origin}' {Accessed ingress URL}
    For example, if the origin is example.com and the accessed ingress URL is 121.**.**.**:80, run the following command:
    curl -X OPTIONS -H 'Origin: example.com' 121.**.**.**:80
    The Access-Control-** request header will be added to the original backend response.
    HTTP/1.1 200 OK
    Access-Control-Allow-Headers: fake-header-1
    Access-Control-Expose-Headers: fake-header-2
    Access-Control-Allow-Methods: GET, POST
    Access-Control-Allow-Credentials: true
    Access-Control-Max-Age: 3600
