Cost Insights for a Cluster
Cost Insights for a cluster helps cost O&M personnel analyze cluster costs and resource usages from multiple dimensions, such as namespace, application, and node pool, to identify applications that can be optimized. Currently, the cluster and namespace dimensions are supported.
- Cost Insights has been enabled.
- Processing bills takes some time. After Cost Insights is enabled, there is about two days delay before you can view your costs.
- Cloud Native Cluster Monitoring must run normally to ensure accurate data displays of namespaces, workloads, and node pools on the Cost Insights page.
Navigation Path
- In the navigation pane, choose Cloud Native Cost Governance > Cost Insights.
- On the displayed page, analyze costs.
Figure 1 Cost Insights for a cluster
Clusters
The Clusters tab displays the cost overview on a cluster, including the cost overhead and resource consumption of namespaces, workloads, and node pools. This helps O&M personnel identify applications with high cost overhead and low resource utilization.
You can filter data by time in the upper right corner.
Parameter |
Description |
Month-to-date costs Month-over-month change |
Month-to-date costs: costs generated by the cluster from the start of the current month to the date of the most recent bill. If Cost Insights is enabled in the current month, the cost is accumulated from the date when Cost Insights is enabled to the date of the most recent bill. Month-over-month change: (Month-to-date costs – Last month same-period costs)/Last month same-period costs |
Forecasted month-end costs Month-over-month change |
Forecasted month-end costs: estimated total costs by the end of the current month. Month-over-month change: (Forecasted month-end costs – Last month total costs)/Last month total costs |
CPU usage Used CPU Total CPU |
CPU usage: average CPU usage of all nodes in the cluster at the current time. Formula: CPU usage = Used CPU on all nodes/Total CPU on all nodes × 100% |
Memory usage Used memory Total memory |
Memory usage: average memory usage of all nodes in the cluster at the current time. Formula: Memory usage = Used memory on all nodes/Total memory on all nodes × 100% |
Cost Breakdown |
Cost breakdown during the specified time period, including the ECS cost, EVS cost, and CCE cluster management cost. |
Daily Costs |
Daily cost breakdown, which can be used to identify resources with high costs in a cluster. |
Parameter |
Description |
Namespace |
Total Namespace Cost indicates the total cost (CPU cost, memory cost, and EVS cost) of the workloads in each selected namespace. Total Resource Cost indicates the total cost of compute resources (all ECSs and EVS disks) used by a cluster. Total resource cost = Total namespace cost + Unallocated cost The larger the gray area is, the more resources are not used, causing resource wastes. |
Top 5 Workloads |
Top 5 workloads with high costs. |
Top 5 Node Pools |
Top 5 mode pools with high costs. |
Module |
Parameter |
Description |
Namespace Cost & Resource Summary |
Namespace |
Namespace name. |
Estimated Cost |
Namespace cost: the cost calculated based on the percentage of total node resources (CPU and memory) that are used in the namespaces, plus the cost of storage used by the workloads in the namespaces. |
Total Core-Hours |
Total number of core-hours consumed by the workloads in a namespace during the specified time period. |
Average CPU Utilization |
Average CPU usage of the workloads in a namespace during the specified time period. CPU usage = Used CPU/CPU request x 100% |
Average Used CPU |
Average CPU used by the workloads in a namespace during the specified time period. |
CPU Request |
CPU request in a namespace on the last day of the specified time period. It is the total CPU request of the workloads in the namespace. |
Average Memory Utilization |
Average memory usage of the workloads in a namespace during the specified time period. Memory usage = Used memory/Memory request x 100% |
Average Used Memory |
Average memory used by the workloads in a namespace during the specified time period. |
Memory Request |
Memory request in a namespace on the last day of the specified time period. It is the total memory request of the workloads in the namespace. |
Workload Cost & Top 5 Costs |
Workload |
Workload name. |
Estimated Cost |
Workload cost: the cost calculated based on the percentage of total node resources (CPU and memory) that are used by a workload, plus the cost of storage used by the workload. |
Total Core-Hours |
Total number of core-hours consumed by a workload during the specified time period. |
Core-Hour Unit Price |
Price per CPU core per hour. If the core-hour unit price of a workload or namespace is high, you can change the node type to reduce costs and improve resource utilization. |
Namespace |
Namespace that a workload belongs to. |
Average CPU usage of a workload during the specified time period. CPU usage = Used CPU/CPU request x 100% |
Average Used CPU |
Average CPU used by a workload during the specified time period. |
CPU Request |
CPU request of a workload on the last day of the specified time period. |
Average memory usage of a workload during the specified time period. Memory usage = Used memory/Memory request × 100% |
Average memory used by a workload during the specified time period. |
Memory Request |
Memory request of a workload on the date of the most recent bill during the specified time period. |
Node Pool Cost & Resource Summary |
Node Pool |
Node pool name. |
Cost |
Cost of nodes in a node pool during the specified time period. |
Average CPU Usage |
Average CPU usage of a node pool during the specified time period. CPU usage = Total CPU used by nodes in a node pool/Total CPU in a node pool × 100% |
Average Used CPU |
Average CPU used by a node pool during the specified time period. |
Idle CPU | Requested CPU | Total CPU |
Idle CPU: total idle CPUs of all nodes in a node pool on the last day of the specified time period. Requested CPU: total CPUs requested by all nodes in a node pool on the last day of the specified time period. Total CPU: total CPUs of all nodes in a node pool on the last day of the specified time period. |
Average Memory Usage |
Average memory usage of a node pool during the specified time period. Memory usage = Total memory used by nodes in a node pool/Total memory in a node pool x 100% |
Average memory used by a node pool during the specified time period. |
Idle Memory | Requested Memory | Total Memory |
Idle Memory: total idle memory of all nodes in a node pool on the last day of the specified time period. Requested Memory: total memory requested by all nodes in a node pool on the last day of the specified time period. Total Memory: total memory of all nodes in a node pool on the last day of the specified time period. |
Namespaces
The Namespaces tab displays the cost optimization analysis on the selected namespace and workloads in that namespace, which allow you to identify workloads with high overhead and low utilization for coat optimization.
Parameter |
Description |
Month-to-date costs: costs generated in selected namespaces from the start of the current month to the date of the most recent bill. If Cost Insights is enabled in the current month, the cost is accumulated from the date when Cost Insights is enabled to the date of the most recent bill. Month-over-month change: (Month-to-date costs – Last month same-period costs)/Last month same-period costs |
Forecasted month-end costs: estimated total costs in the selected namespaces by the end of the current month. Month-over-month change: (Forecasted month-end costs – Last month total costs)/Last month total costs |
CPU utilization Used CPU CPU request |
CPU utilization: average CPU usage in the selected namespaces at the current time. Formula: CPU usage = Total used CPU in the selected namespaces/Total CPU requests in the selected namespaces × 100% |
Memory utilization Used memory Memory request |
Memory utilization: Average memory usage in the selected namespaces at the current time. Formula: Memory usage = Total used memory in the selected namespaces/Total memory requests in the selected namespaces × 100% |
Cost Breakdown |
Cost breakdown of top 5 namespaces among the selected namespaces during the specified time period. |
Daily Costs |
Daily cost breakdown of the selected namespaces for identifying namespaces with high costs. |
Parameter |
Description |
Resource Costs |
Costs of resources in the selected namespaces during the specified time period, which consist of the CPU cost, memory cost, and storage cost. |
Core-Hour Unit Prices |
Average unit prices of core-hours consumed by workloads on the nodes in the selected namespaces. |
Top 5 Namespaces by Core-Hours |
Total core-hours consumed by resources in top 5 namespaces among the selected namespaces during the specified time period. |
CPU |
Changes of CPU usages, requests, and limits in the selected namespaces. |
Memory |
Changes of memory usages, requests, and limits in the selected namespaces. |
Resource Utilization |
Changes of CPU usages and memory usages in the selected namespaces. |
Parameter |
Description |
Workload |
Workload name. |
Estimated Cost |
The cost calculated based on the percentage of total node resources (CPU and memory) that are used by a workload, plus the cost of storage used by the workload. |
Total Core-Hours |
Total number of core-hours consumed by a workload during the specified time period, reflecting the CPU usage. |
Price per CPU core per hour of the node where the workload is located, which can be used for node model optimization. |
Namespace |
Average CPU usage of a workload during the specified time period. CPU usage = Used CPU/CPU request × 100% |
Average Used CPU |
CPU Request |
Memory Request |
Memory request of a workload on the last day of the specified time period. |
