Updated on 2025-07-17 GMT+08:00
Overview
By leveraging the experience of our container O&M experts, health diagnosis monitors cluster health to detect cluster faults and identify risks in a timely manner. It also provides rectification suggestions.
Health Diagnosis Coverage
The following figure shows the health diagnosis coverage.
Figure 1 Health diagnosis coverage
Health Diagnosis Capabilities
  • Out-of-the-box diagnosis (without Monitoring Center enabled)
  • Comprehensive check of cluster health (with Monitoring Center enabled)
  • Health scores based on diagnosis results
  • Scheduled inspection and visualized inspection results
  • Inspection history for analyzing fault causes
  • Risk levels and rectification suggestions
Application Scenarios
  • You can check the cluster health before a cluster change and perform health diagnosis at any time.
  • You can set a scheduled inspection to identify cluster risks on schedule.
The following table lists the inspection items.
Dimension
Inspection Item
O&M
  • Cluster O&M
  • Cluster security group configuration
  • Cluster resource planning
  • Resource quotas allocated to a tenant
Resources and services
  • Storage add-on (Everest) status
  • Log collection add-on (log-agent) status
  • Domain name resolution add-on (CoreDNS) status
  • Worker node load status
  • Worker node status
  • Pod configuration
  • Pod workload
  • Pod status
For more information, see Diagnosis Items and Rectification Solutions.
