Updated on 2026-04-03 GMT+08:00
Local EV
Local Ephemeral Volumes (EVs) are stored in EV storage pools. Local EVs deliver better performance than the default storage medium of native emptyDir and support scale-out.
  • Local EVs are supported only when the cluster version is v1.21.2-r0 or later and the Everest add-on version is v1.2.29 or later.
  • Do not manually delete the corresponding storage pool or detach data disks from the node. Otherwise, exceptions such as data loss may occur.
  • Ensure that the /var/lib/kubelet/pods/ directory is not mounted to the pod on the node. Otherwise, the pod, mounted with such volumes, may fail to be deleted.
Using a Local EV
CCE allows you to use local EVs via the console or kubectl. To do so, perform the following operations.
  2. Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
  3. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > Local EV (emptyDir).
  4. Mount and use storage volumes. For details about the parameters, see Table 1. For other parameters, see Workloads.
    Table 1 Mounting a local EV
    Capacity (GiB)
    Capacity of the requested storage volume.
    Mount Path
    Enter a mount path, for example, /tmp.
    This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
    NOTICE:
    If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
    Subpath
    Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
    Permission
    • Read-only: You can only read the data in the mounted volumes.
    • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
  5. After the configuration, click Create Workload.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a file named nginx-emptydir.yaml and edit it.
    vi nginx-emptydir.yaml
    Content of the YAML file:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: nginx-emptydir
      template:
          labels:
            app: nginx-emptydir
          containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
                - name: vol-emptydir         # Volume name, which must be the same as the volume name in the volumes field.
                  mountPath: /tmp            # Mount path of the emptyDir volume
          imagePullSecrets:
            - name: default-secret
          volumes:
            - name: vol-emptydir             # Volume name, which is user-defined
              emptyDir:
                medium: LocalVolume          # If the disk medium of emptyDir is set to LocalVolume, the local EV is used.
                sizeLimit: 1Gi               # Volume capacity
  3. Create a workload.
    kubectl apply -f nginx-emptydir.yaml
Handling Local EV Exceptions
If a user manually detaches a disk from ECS or manually runs the vgremove command, the EV storage pool may malfunction. To resolve this issue, set the node to be unschedulable by following the procedure described in Configuring a Node Scheduling Policy in One-Click Mode and then reset the node.
