Migrating a Node
Migration Scenario | Migration | Operation | |
Source Node Pool | Target Node Pool | ||
Custom node pool | Default node pool (DefaultPool) | Supported | Migrating Nodes from a Custom Node Pool to the Default Node Pool |
Default node pool (DefaultPool) | Custom node pool | Supported by clusters of v1.23 or later | Migrating Nodes from the Default Node Pool to a Custom Node Pool |
Custom node pool | Custom node pool | Not supported | None |
- In the navigation pane, choose Nodes and click the Node Pools tab.
- Click View Node in the Operation column of the node pool to be migrated.
- Choose More > Migrate Node in the Operation column of the target node to migrate the node.Figure 1 Migrating nodes to the default node pool
- In the Migrate Node dialog box, confirm the information.
- The migration does not affect custom resource tags, and Kubernetes labels and taints of the node.
- The migration does not affect the kubelet, kube-proxy, container runtime, and node OS settings of the node.
- After the migration, system labels cce.cloud.com and cce-nodepool on the node will be deleted. If an existing workload uses these labels for affinity or anti-affinity scheduling, the existing pods on the node will be stopped and rescheduled when kubelet is restarted.
Nodes cannot be migrated to spot pricing node pools.
- Locate the target node pool and choose More > Migrate Node.Figure 2 Migrating nodes to a custom node pool
- In the Migrate Node dialog box, select the nodes that meet the following conditions:
- The nodes and the current node pool are deployed in the same VPC and subnet.
- The nodes and the current node pool belong to the same enterprise project.
- The nodes and the current node pool are in the same cloud server group.
- The billing mode of the nodes is supported by the current node pool.
- The nodes are running and they are from the default node pool.
- The flavor, AZ, resource reservation, container runtime, and OS configurations of the nodes are the same as those of the node pool.
- Click OK.
- After migration, node pool configurations (including resource tags, Kubernetes labels, taints, and Kubernetes component settings) will overwrite conflicting node settings.
- After the migration, the pool's security group will take over the nodes' original security group.
- After the migration, the pool's agency will take over the nodes' original agency.
- After the migration, the nodes' original login mode will remain unchanged.
- After a node is migrated to a node pool after being accepted by the cluster, its acceptance tag will be removed. Scaling in the node pool may result in the removal of the node.
