Help Center/
Cloud Container Engine/
User Guide/
Node Pools/
Managing Node Pools/
Synchronizing Node Pools
Updated on 2025-07-17 GMT+08:00
After the configuration of a node pool is updated, some configurations cannot be automatically synchronized for existing nodes. You can manually synchronize configurations for these nodes.
- Do not delete or reset nodes during batch synchronization. Otherwise, the synchronization of node pool configuration may fail.
- This operation involves resetting nodes. Workloads running on a node may be interrupted due to standalone deployment or insufficient schedulable resources. Evaluate the upgrade risks and perform the upgrade during off-peak hours. Alternatively, specify a disruption budget for your key applications to ensure the availability of these applications during the upgrade.
- During configuration synchronization for existing nodes, the nodes will be reset, and the system disks and data disks will be cleared. Back up important data before the synchronization.
- Only some node pool parameters can be synchronized by resetting nodes. The constraints are as follows:
- Only clusters of v1.19 or later support the modification of the container engine, OS, system/data disk size, data disk space allocation, and pre-installation/post-installation script configuration.
- Changes to the container engine, OS, or pre-/post-installation script in a node pool take effect only on new nodes. To synchronize the modification onto existing nodes, manually reset these nodes.
- The modification of data disk space allocation and the system/data disk size of a node pool takes effect only for new nodes. The configuration cannot be synchronized even if the existing nodes are reset.
- Changes to resource tags and Kubernetes labels/taints in a node pool will be automatically synchronized to existing nodes after the options of Synchronization for Existing Nodes are selected. You do not need to reset these nodes.
Synchronizing a Single Node
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Nodes tab.
- Find the node marked with Node pool updated in the node pool.
- Move the cursor to Node pool updated. The Reset button is displayed. You can then determine whether to reset the node immediately.
Batch Synchronization
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
- Choose More > Synchronize in the Operation column of the target node pool.
- In the Batch synchronization window, configure parameters.
- OS: shows the image of the target version. You do not need to configure this parameter.
- Synchronization Type: Reset node is supported.
- Max. Nodes for Batch Synchronization: maximum number of nodes that will be unavailable during node synchronization. Nodes will be unavailable during synchronization by resetting the nodes. Properly configure this parameter to prevent pod scheduling failures caused by too many unavailable nodes in the cluster.
- In the node list, select the nodes requiring the synchronization of node pool configurations.
- Click OK.
