Help Center/ Cloud Container Engine/ User Guide/ Storage/ OBS/ Configuring OBS Mount Options
Updated on 2026-08-13 GMT+08:00
This section describes how to configure OBS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
The CCE Container Storage (Everest) version must be 1.2.8 or later. This add-on identifies the mount options and transfers them to the underlying storage resources. The parameter settings take effect only if the underlying storage resources support the specified options.
Mount options cannot be configured for secure containers.
OBS Mount Options
When mounting an OBS volume, the Everest add-on presets the options described in Table 1 and Table 2 by default. The options in Table 1 are mandatory.
Table 1 Mandatory mount options configured by default
Supported Object StorageClass
Value
use_ino
Parallel file system
Blank
If enabled, obsfs allocates the inode number. Enabled by default in read/write mode.
big_writes
Object bucket
Blank
If enabled, the maximum size of the write cache can be changed.
nonempty
Object bucket
Blank
Allows non-empty mount paths.
allow_other
Object bucket
Blank
Allows other users to access the mount directory.
no_check_certificate
Object bucket
Blank
Disables server certificate verification.
enable_noobj_cache
Object bucket
Blank
Enables cache entries for objects that do not exist, which can improve performance. Enabled by default in object bucket read/write mode.
This option is no longer configured by default since Everest 1.2.40.
sigv2
Object bucket
Blank
Specifies the signature version. Used by default in object buckets.
public_bucket
Object bucket
If this parameter is set to 1, public buckets are mounted anonymously. Enabled by default in object bucket read-only mode.
compat_dir
Object bucket
Blank
This parameter is automatically added when s3fs v1.92 is used. Multi-level directory objects in a bucket can be displayed.
Table 2 Optional mount options configured by default
Value
max_write
Object bucket
131072
This parameter is valid only when big_writes is configured. The recommended value is 128 KB.
multipart_size
Object bucket
20
If a file is uploaded in multiple parts, the size of each part, measured in MB, will affect the size of the file that can be uploaded.
ssl_verify_hostname
Object bucket
0
Disables SSL certificate verification based on the host name. If this parameter is set to 1, SSL verification is enabled. Ensure the OBS server certificate is issued by a trusted CA. Otherwise, volume mounting will fail.
max_background
Object bucket
100
Allows setting the maximum number of waiting requests in the background. Used by default in parallel file systems.
umask
Object bucket
0
Mask of the configuration file permission.
For example, if the umask value is 022, the directory permission (the maximum permission is 777) is 755 (777 - 022 = 755, rwxr-xr-x).
Configuring Mount Options
You can configure mount options using one of the following methods.
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in OBS Mount Options.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Configure mount options in a PV. Example:
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
        everest.io/reclaim-policy: retain-volume-only      # (Optional) The underlying volume is retained when the PV is deleted.
      name: pv-obs       # PV name
      accessModes:
      - ReadWriteMany    # Access mode. The value must be ReadWriteMany for OBS.
      capacity:
        storage: 1Gi     # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect.
      csi:
        driver: obs.csi.everest.io        # Dependent storage driver for the mounting
        fsType: obsfs                     # Instance type
        volumeHandle: <your_volume_id>    # Name of the OBS volume
        volumeAttributes:
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
          everest.io/obs-volume-type: STANDARD
          everest.io/region: <your_region>                        # Region where the OBS volume is
          everest.io/enterprise-project-id: <your_enterprise_project_id>     # (Optional) Enterprise project ID of an OBS volume. This parameter is available only for enterprise accounts with enterprise projects enabled. If an enterprise project is specified, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot bind to a PV.
        nodePublishSecretRef:            # Custom secret of the OBS volume
          name: <your_secret_name>       # Custom secret name
          namespace: <your_namespace>    # Namespace of the custom secret
      persistentVolumeReclaimPolicy: Retain    # Reclaim policy
      storageClassName: csi-obs               # StorageClass name
      mountOptions:                            # Mount options
      - umask=027
  3. After creating a PV, you can create a PVC, bind it to the PV, and mount the PV to the containers in the workload. For details, see Using an Existing OBS Bucket Through a Static PV.
  4. Check whether the mount options are effective.
    In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can log in to the node where the pod to which the OBS volume is mounted resides and view the progress details.
    Run the following command:
    • Object bucket: ps -ef | grep s3fs
      root     22142     1  0 Jun03 ?        00:00:00 /usr/bin/s3fs {your_obs_name} /mnt/paas/kubernetes/kubelet/pods/{pod_uid}/volumes/kubernetes.io~csi/{your_pv_name}/mount -o url=https://{endpoint}:443 -o endpoint={region} -o passwd_file=/opt/everest-host-connector/***_obstmpcred/{your_obs_name} -o nonempty -o big_writes -o sigv2 -o allow_other -o no_check_certificate -o ssl_verify_hostname=0 -o umask=027 -o max_write=131072 -o multipart_size=20
    • Parallel file system: ps -ef | grep obsfs
      root      1355     1  0 Jun03 ?        00:03:16 /usr/bin/obsfs {your_obs_name} /mnt/paas/kubernetes/kubelet/pods/{pod_uid}/volumes/kubernetes.io~csi/{your_pv_name}/mount -o url=https://{endpoint}:443 -o endpoint={region} -o passwd_file=/opt/everest-host-connector/***_obstmpcred/{your_obs_name} -o allow_other -o nonempty -o big_writes -o use_ino -o no_check_certificate -o ssl_verify_hostname=0 -o max_background=100 -o umask=027 -o max_write=131072
You can use mountOptions to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in OBS Mount Options.
  2. Create a custom StorageClass. Example:
    kind: StorageClass
    apiVersion: storage.k8s.io/v1
    provisioner: everest-csi-provisioner
    parameters:
      csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io
      csi.storage.k8s.io/fstype: s3fs
    reclaimPolicy: Delete
    volumeBindingMode: Immediate
    - umask=027
  3. After the StorageClass is configured, you can use it to create a PVC. By default, dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an OBS Bucket Through a Dynamic PV.
