Updated on 2025-11-06 GMT+08:00
Node Statuses
Check Items
After a cluster is upgraded, check whether nodes in the cluster are in the Running state.
CCE automatically checks your node statuses. Go to the node list page and confirm the node statuses based on the diagnosis result.
Solution
If a node malfunctions, reset the node. If the fault persists, contact technical support.
