Nodes' System Parameters
Check Items
Check whether the system parameters on your node meet the expectation.
- Scenario 1: If the MTU value of the bond0 network on your BMS node is not the default value 1500, this check item will fail.
Non-default parameter settings may lead to service packet loss. Change them back to the default values. Take the following steps:
- Disable bond0.
sudo ip link set dev bond0 down
Disabling bond0 will interrupt services. Exercise caution when performing this operation.
- Change the MTU value to 1500.
sudo ip link set dev bond0 mtu 1500
- Restart bond0.
sudo ip link set dev bond0 up
- Verify the modification result. (Ensure that the MTU has been updated.)
ip link show dev bond0 | grep mtu
If the command output is mtu 1500, the setting has been modified.
- Disable bond0.
- Scenario 2: If you upgrade the cluster to v1.29 or later, the kernel parameter nf_contrack_max is set by kube-proxy. If the value of this parameter is greater than that of conntrack-min configured for kube-proxy, this check item will fail. You are advised to use the kube-proxy startup parameter conntrack-min to ensure that the kernel parameter value is not less than the value configured on the current node after the upgrade.
- View the nf_contrack_max kernel parameter configuration.
cat /proc/sys/net/netfilter/nf_conntrack_max
- Modify the conntrack-min of kube-proxy through node pool configuration management. Set it to the value of the nf_contrack_max kernel parameter on the current node (which is the value queried in the previous step).
