Updated on 2026-01-04 GMT+08:00
Key Node Commands
Check Items
Whether some key commands that the node upgrade depends on are working
  • Scenario 1: Executing the RPM package manager command failed.
    Executing rpm failed. In this case, log in to the affected node and check whether the following command is available:
    rpm -qa
    If the command cannot be used, run the following command:
    rpm --rebuilddb
    If the fault persists, reset the node. For details, see Resetting a Node.
  • Scenario 2: Executing the dpkg package manager command failed.
    Executing dpkg failed. In this case, log in to the affected node and check whether the following command is available:
    dpkg -l
    If the command cannot be used, reset the node. For details, see Resetting a Node.
  • Scenario 3: Executing systemctl status failed.
    If systemctl status cannot be used on a node, many check items will fail. In this case, log in to the affected node and check whether the following command is available:
    systemctl status kubelet
    If systemctl cannot be used, reset the node. For details, see Resetting a Node.
