Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ Node ID File
Updated on 2026-06-16 GMT+08:00
Node ID File
Check Items
Check the ID file format.
- On the Nodes page of the CCE console, click the name of the abnormal node to go to the ECS page.
- Copy the node ID and save it to the local host. Figure 1 Copying a node ID
- Log in to the abnormal node and back up the file.
cp /var/lib/cloud/data/instance-id /tmp/instance-id cp /var/paas/conf/server.conf /tmp/server.conf
- Log in to the abnormal node and write the obtained node ID to the file.
echo Node ID > /var/lib/cloud/data/instance-id echo Node ID > /var/paas/conf/server.conf
