Enhanced CPU Policies
Check Items
Check whether the current cluster version and the target version support enhanced CPU policy.
Solution
Scenario: Only the current cluster version supports the enhanced CPU policy function. The target version does not support the enhanced CPU policy function.
Upgrade to a cluster version that supports the enhanced CPU policy function. The following table lists the cluster versions that support the enhanced CPU policy function.
Cluster Version |
Enhanced CPU Policy |
Clusters of v1.17 or earlier |
Not supported |
Clusters of v1.19 |
Not supported |
Clusters of v1.21 |
Not supported |
Clusters of v1.23 or later |
Supported |
