Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ kubelet
Updated on 2025-11-06 GMT+08:00
kubelet
Check Items
Check whether the kubelet on the node is running properly.
- Scenario: The kubelet status is abnormal.
If the kubelet malfunctions, the node will be unavailable. Restore the node and check again. For details, see What Should I Do If a Cluster Is Available But Some Nodes in It Are Unavailable?
