Updated on 2026-06-16 GMT+08:00
Add-ons
Check Items
Check the following items:
  • Check whether the add-on status is normal.
  • Check whether the add-on supports the target version.
  • Scenario 1: The add-on malfunctions.
    Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane and obtain the malfunctional add-on. Then, rectify the fault.
    Figure 1 Checking the add-on status
  • Scenario 2: The target version of the cluster upgrade does not support the add-on.
    The following error information is displayed during the pre-upgrade check:
    addon [***] does not support cluster target version, check and try again
    Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane and manually uninstall the add-on. For details about the supported add-on versions and substitutions, see the Help document.
  • Scenario 3: The add-on configuration does not meet the upgrade requirements. Upgrade the add-on and try again.
    please upgrade addon [ ] in the page of addon managecheck and try again
    In this case, log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane and manually upgrade the add-on.
