Changing the RuntimeMaxUse of the Memory Used by the Log Cache on a Node
Journald is a log system in Linux. It writes log information into binary files and uses /run/log/journal as the log cache directory by default. The Journald configuration file is stored in the /etc/systemd/journald.conf directory on the node. The RuntimeMaxUse parameter indicates the maximum memory usage of the log cache. If RuntimeMaxUse is not set, a large amount of memory will be occupied after the system runs for a long time.
- Commands for modifying node system parameters are valid only when public images are used. For private images, the commands in this section are for reference only.
- Directly logging in to a node to modify system parameters may cause changes to be lost during subsequent node reset or upgrade, affecting running services. Fully evaluate the risks before proceeding. Use a pre-installation script or post-installation script to modify the node parameters instead.
Logging In to the Node to Change RuntimeMaxUse
- Log in to the node and view the /etc/systemd/journald.conf file.
cat /etc/systemd/journald.conf
- Modify RuntimeMaxUse. The recommended value is 100M.
- If RuntimeMaxUse is already set in journald.conf, run the following command to change the value:
sed -i "s/RuntimeMaxUse=[0-9]*M/RuntimeMaxUse=100M/g" /etc/systemd/journald.conf && systemctl restart systemd-journald
- If RuntimeMaxUse is not set in journald.conf, run the following command to set it:
echo RuntimeMaxUse=100M >> /etc/systemd/journald.conf && systemctl restart systemd-journald
- Verify the modification. If the returned value matches your configuration, the modification is correct.
cat /etc/systemd/journald.conf | grep RuntimeMaxUse
Automatically Configuring RuntimeMaxUse When Creating a Node or Node Pool
You can set the script to be executed after a node or node pool is created. When creating a node or node pool, you can use the script to configure the RuntimeMaxUse size.
- Confirm the OS of the node or node pool to be created, for example, CentOS 7.6.
- Manually test the script commands on nodes in the same cluster and running the same OS. For details about how to manually run the script, see Logging In to the Node to Change RuntimeMaxUse.
- When creating a node or node pool, choose Advanced Settings > Post-installation script to add the commands. The commands must be verified as executable before configuration.
- Log in to the node and view the /etc/systemd/journald.conf file. If RuntimeMaxUse has been set, run the following command to change the value:
- Log in to the node and view the /etc/systemd/journald.conf file. If RuntimeMaxUse is not set, run the following command to add it:
The command in the following figure is used only as an example. Change it as needed.
- After node creation, log in to the node and verify that the parameter was modified successfully.
