Changing Process ID Limits (kernel.pid_max)
Context
Process IDs (PIDs) are a fundamental resource on nodes. It is trivial to hit the task limit without hitting any other resource limits, which can then cause instability to a host machine.
You can adjust the PID limit (kernel.pid_max) according to service requirements.
kernel.pid_max Defaults
By the end of January 2022, CCE changed the default value of kernel.pid_max to 4194304 for EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04 nodes in clusters v1.17 or later. Specific conditions:
- Cluster version: v1.17.17 or later
- Time when nodes were created: after January 30, 2022
If the preceding two conditions are not met, kernel.pid_max on EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04 nodes defaults to 32768.
| OS | Clusters of 1.17.9 and Earlier | Clusters of 1.17.17 and Later | |
| Nodes Created on or Before January 30, 2022 | Nodes Created After January 30, 2022 | ||
| EulerOS 2.5 | 32768 | 32768 | 4194304 |
| CentOS 7.6 | 32768 | 32768 | 4194304 |
| Ubuntu 18.04 | N/A | 32768 | 4194304 |
| EulerOS 2.3 | 57344 | 57344 | 57344 |
| EulerOS 2.9 | N/A | 4194304 | 4194304 |
| Huawei Cloud EulerOS 2.0 | N/A | N/A | 4194304 |
| Ubuntu 22.04 | N/A | N/A | 4194304 |
| Huawei Cloud EulerOS 1.1 | N/A | N/A | 4194304 |
Change Suggestion
- EulerOS 2.3: Change the default to 4194304 for all nodes. For details, see Changing kernel.pid_max of a Node. Use a pre-installation script to do so for new nodes and node pools. For details, see Configuring kernel.pid_max When Creating a Node Pool and Configuring kernel.pid_max When Creating a Node.
- EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04:
- Change the value of kernel.pid_max to 4194304 for nodes created on January 30, 2022 or earlier in clusters v1.17.17 or later. For details, see Changing kernel.pid_max of a Node.
- For clusters v1.17.9 and earlier:
- Change the value of kernel.pid_max to 4194304 for existing nodes. For details, see Changing kernel.pid_max of a Node.
- Use a pre-installation script to do so for new nodes and node pools. For details, see Configuring kernel.pid_max When Creating a Node Pool and Configuring kernel.pid_max When Creating a Node.
Viewing kernel.pid_max
Log in to the node and run the following command to obtain the value of kernel.pid_max:
sysctl kernel.pid_max
Command output:
kernel.pid_max = 32768
Change kernel.pid_max, if necessary, as instructed in Changing kernel.pid_max of a Node.
Checking Node PIDs
Log in to the node and run the following command to check how many PIDs are in use:
ps -eflL | wc -l
Command output:
691
Log in to the node and run the following command. 4194304 indicates the value of kernel.pid_max and is used as an example here.
echo kernel.pid_max = 4194304 >> /etc/sysctl.conf && sysctl -p
Run the following command to check whether the returned value is the same as that you configured:
Command output:
EulerOS 2.3: Configuration required.
For a node pool running EulerOS 2.5, CentOS 7.6, or Ubuntu 18.04 in a cluster v1.17.9 or earlier, kernel.pid_max is required. In clusters v1.17.17 or later, kernel.pid_max has been changed to 4194304 in the OS image and does not need to be configured.
You can configure kernel.pid_max using the pre-installation script when creating a node in a node pool.
When creating a node pool, choose Advanced Settings > Post-installation Command and add the following command:
You can configure kernel.pid_max using the pre-installation script when creating a node.
When creating a node, choose Advanced Settings > Post-installation Command and add the following command:
