Updated on 2025-07-17 GMT+08:00
Headless Service
Headless Services are a special type of Kubernetes Service. They do not provide a cluster IP address or load balancing through a Service IP address. Instead, when a client uses the DNS name of a headless Service for query, Kubernetes directly returns the individual IP addresses of the pods selected by the Service. This design allows clients to connect directly to the pods themselves. Headless Services are ideal for certain applications such as database clusters and cache clusters.
Headless Services are typically used in:
  • StatefulSets: In StatefulSets such as MySQL, Kafka, and Elasticsearch, each pod has unique responsibilities and does not require load balancing. A headless Service gives each pod its own access entry.
  • Applications that need custom load balancing: Some applications need to manage their own load balancing policies rather than relying on Kubernetes' default load balancing policy.
Creating a Headless Service
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a StatefulSet and an associated headless Service.
    vi headless.yaml
    File content:
    apiVersion: v1
    kind: Service       # Set the resource object type to Service.
      labels:
        app: nginx
      ports:
        - name: web       # Name of the port for communications between pods
          port: 80        # Port number for communications between pods
      selector:
        app: nginx        # Select the pod labeled with app:nginx.
      clusterIP: None     # Set this parameter to None, indicating that a headless Service will be created.
    apiVersion: apps/v1
    kind: StatefulSet
      serviceName: nginx-headless   # Name of the headless Service associated with the StatefulSet
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          containers:
          - name: nginx
            image: nginx:alpine
            ports:
            - containerPort: 80
          imagePullSecrets:
            - name: default-secret
  3. Create the StatefulSet and headless Service.
    kubectl create -f headless.yaml
  4. Check whether the pods have been created.
    kubectl get pods -l app=nginx -o wide
    Information similar to the following is displayed:
    NAME     READY   STATUS    RESTARTS   AGE     IP          NODE            NOMINATED NODE   READINESS GATES
    web-0    1/1     Running   0          41s     10.0.0.22   192.168.0.194   <none>           <none>
    web-1    1/1     Running   0          38s     10.0.0.23   192.168.0.194   <none>           <none>
    web-2    1/1     Running   0          37s     10.0.0.39   192.168.0.21    <none>           <none>
  5. Check whether the headless Service has been created.
    kubectl get svc nginx-headless
    NAME             TYPE        CLUSTER-IP   EXTERNAL-IP   PORT(S)   AGE
    nginx-headless   ClusterIP   None         <none>        80/TCP    2m20s
  6. Create a temporary pod to obtain DNS.
    kubectl run -it --rm --image=busybox:1.28 test-pod -- sh
    The command for obtaining DNS is as follows:
    nslookup nginx-headless
    Server:    10.247.3.10
    Address 1: 10.247.3.10 coredns.kube-system.svc.cluster.local
    Address 1: 10.0.0.22 web-0.nginx-headless.default.svc.cluster.local
    Address 2: 10.0.0.23 web-1.nginx-headless.default.svc.cluster.local
    Address 3: 10.0.0.39 web-2.nginx-headless.default.svc.cluster.local
    This indicates that each StatefulSet pod has an independent DNS record.
  7. Check whether these pods can be accessed.
    wget -qO- web-0.nginx-headless
