Help Center/ Cloud Container Engine/ User Guide/ Networking/ Cluster Network Settings/ Adding a Secondary VPC CIDR Block for a Cluster
Updated on 2026-06-16 GMT+08:00
When creating a cluster, deploy it in a VPC. If the planned VPC is too small and IP addresses are insufficient, you can use a secondary VPC CIDR block to support your service scaling. This section describes how to add a secondary VPC CIDR block for your cluster.
Notes and Constraints
Only CCE standard clusters and CCE Turbo clusters of v1.21 and later versions are supported.
Planning a Secondary CIDR Block
Before adding a secondary CIDR block, plan it properly to prevent CIDR conflicts. Note the following points:
  • All subnets (including those created from the secondary CIDR blocks) in the VPC where the cluster resides cannot conflict with the container or Service CIDR block.
  • Do not use CIDR blocks 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 as secondary CIDR blocks, as they may conflict with IP addresses allocated to cluster master nodes.
  • In a cluster that uses a VPC network, when an ECS outside the cluster (but in the same VPC as it) communicates with the cluster, SNAT is applied. As a result, the pod's source IP address is translated to the node IP address.
  • In a cluster that uses a VPC network, once you add a node from a secondary CIDR block, the cluster security group automatically allows traffic from that secondary CIDR block, enabling ECSs in the secondary CIDR block to access pods within the cluster. If no nodes are added from the secondary CIDR block and the cluster's security group does not allow any traffic from it, ECSs in that secondary CIDR block cannot access pods within the cluster.
  • For a CCE Turbo cluster, you must manually update the network interface security group to allow traffic from the secondary CIDR block so that ECSs in that CIDR block can access pods within the cluster. For details, see How Can I Configure a Security Group Rule for a Cluster?
  1. Log in to the VPC console. In the navigation pane, choose Virtual Private Cloud > My VPCs. In the Operation column of the VPC that the cluster belongs to, click Edit CIDR Block and then Add Secondary IPv4 CIDR Block.
    Enter the secondary CIDR block to be added, for example, 192.169.0.0/16.
    Figure 1 Adding a secondary IPv4 CIDR block
  2. In the navigation pane, choose Virtual Private Cloud > Subnets. Click Create Subnet. In IPv4 CIDR Block, enter the new secondary IPv4 CIDR block. Configure other parameters as planned and click OK. Then, you can create subnets in the secondary IPv4 CIDR block for the cluster.
  3. After a subnet is created using the secondary IPv4 CIDR block, select the subnet when creating a node or node pool in the Network Settings area.
