CCE Secrets Manager for DEW
Introduction
The CCE Secrets Manager for DEW add-on (formerly dew-provider) is used to interconnect with Data Encryption Workshop (DEW). It allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration. With this add-on, you can enjoy the following capabilities:
- Mounting secrets: You can mount secrets in DEW to service pods, reducing information leakage risks.
- Scheduled rotation: After a pod runs normally, if the secret declared in the SecretProviderClass object and stored in CSMS is updated, the latest secret values can be updated to the pod through scheduled rotation. When using this capability, set the secret version to latest.
- Real-time detection of SecretProviderClass changes: After a pod runs normally, if a user modifies the secret declared in the SecretProviderClass object (for example, a secret is added or the version number is changed), the add-on can detect the change in real time and update the secret to the pod.
Notes and Constraints
- DEW includes Key Management Service (KMS), Cloud Secret Management Service (CSMS), and Key Pair Service (KPS). This add-on can only connect to Cloud Secret Management Service (CSMS).
- A maximum of 500 SecretProviderClass objects can be created.
- When the add-on is uninstalled, related CRD resources are deleted accordingly. Even if the add-on is reinstalled, the original SecretProviderClass object is unavailable. If you want to use the original SecretProviderClass resources after the add-on is uninstalled and then reinstalled, manually create them again.
Installing the Add-on
- In the navigation pane, choose Add-ons. Locate CCE Secrets Manager for DEW on the right and click Install.
- On the Install Add-on page, configure parameters in the Parameters area, as listed in the following table.
Item
Secret Synchronization Period
rotation_poll_interval
Rotation interval, in unit of m (instead of min).
The rotation interval indicates the interval for sending a request to CSMS and obtaining the latest secret. The proper interval range is [1m, 1440m]. The default value is 2m.
- Click Install.
After the add-on is installed, select the cluster and choose Add-ons in the navigation pane. On the displayed page, view the add-on in the Add-ons Installed area.
Components
Component |
Description |
Resource Type |
dew-provider |
A component that obtains specified secrets from CSMS and mounts them to the pods |
DaemonSet |
csi-secrets-store |
A component that maintains two CRDs, SecretProviderClass and SecretProviderClassPodStatus (spcPodStatus). SecretProviderClass is used to describe the required secret (such as the secret version and name). It is created by users and will be referenced in pods. spcPodStatus is used to trace the binding relationships between pods and secrets. It is automatically created by csi-driver and requires no manual operation. One pod corresponds to one spcPodStatus. After a pod is started, a spcPodStatus is generated for the pod. When the pod lifecycle ends, the spcPodStatus is deleted accordingly. |
DaemonSet |
Mounting Secrets
To mount a secret in DEW to a container, you need to take the following steps: First, create a ServiceAccount object as the secret for the cluster to access DEW. Then, create a SecretProviderClass object to define and obtain the secret in DEW. Finally, mount the ServiceAccount and SecretProviderClass objects to the service pod to ensure that the pod can securely access the secret. Currently, there are two methods to mount a secret to a pod:
- Mounting a secret through a volume: Secrets are mounted to containers in the form of volumes. This method is suitable when there is a large amount of data.
- Mounting a secret created from a secret in DEW: Secrets are mounted to containers as environment variables. This method is suitable when there is only a small amount of sensitive data.
The following describes the processes of the two methods.
- Create a ServiceAccount object to declare the name of the secret that can be used by the service pod. Before you take this step, ensure that the corresponding secret exists in CSMS. If the secret does not exist, an error occurs when the secret is obtained from CSMS. As a result, the pod cannot run normally. For details about how to create secrets in CSMS, see Creating a Secret.
Figure 1 Secrets in DEW
- Create a YAML file for the ServiceAccount object.
vim serviceaccount.yaml
The following is the file content. You can declare the secret names that can be used by the service pod in the cce.io/dew-resource field. In this example, secret_1 and secret_2 can be referenced in the service pod. If you reference a secret that is not declared here, the mounting will fail. As a result, the pod cannot run normally.
apiVersion: v1 kind: ServiceAccount metadata: name: nginx-spc-sa annotations: cce.io/dew-resource: "[\"secret_1\",\"secret_2\"]" #secrets that allow pod to use
- Create the ServiceAccount object.
kubectl apply -f serviceaccount.yaml
Information similar to the following is displayed:
serviceaccount/nginx-spc-sa created
- Check whether the ServiceAccount object has been created.
kubectl get sa
If the following information is displayed, the ServiceAccount object named nginx-spc-sa has been created and will be referenced in the service pods.
NAME SECRETS AGE default 1 18d # This is the default ServiceAccount object of the system. nginx-spc-sa 1 19s # This is the newly created ServiceAccount object.
- Create a SecretProviderClass object to define and manage secrets from DEW so that secrets can be securely mounted to pods in the CCE cluster.
- Create a YAML file for the SecretProviderClass object.
vim secretproviderclass.yaml
The following is the file content. The parameters.objects field specifies the secrets to be mounted, in array format.
apiVersion: secrets-store.csi.x-k8s.io/v1 kind: SecretProviderClass metadata: name: spc-test spec: provider: cce # The value is fixed at cce. parameters: objects: | - objectName: "secret_1" objectAlias: "secret_test" objectVersion: "v1" objectType: "csms"
Table 2 objects parameters Parameter
Type
Mandatory
objectName
String
Yes
Secret name. Set this parameter to the secrets referenced in ServiceAccount. If there are multiple object names defined in the same SecretProviderClass, each value of the objectName parameter must be unique. Otherwise, the mounting fails.
objectAlias
String
No
File name of the secret written into the container.
- If this parameter is not specified, the name of the file that the secret is written to the container is objectName by default.
- If this parameter is specified, the value of objectAlias must be different from that of objectName and of objectAlias of other secrets and its own objectName. Otherwise, the mounting fails.
objectType
String
Yes
Type of the secret. Only csms is supported. A value other than csms is invalid.
objectVersion
String
Yes
Version of the secret.
- Specify a version, for example, v1 or v2.
- Use the latest version, for example, latest. If objectVersion is set to latest and the corresponding secret in CSMS is updated, scheduled rotation is automatically enabled, and the secret will be updated to the pod after the interval specified by rotation_poll_interval.
- Create the SecretProviderClass object.
kubectl apply -f secretproviderclass.yaml
secretproviderclass/spc-test created
- Check whether the SecretProviderClass object has been created.
kubectl get spc
If the following information is displayed, a SecretProviderClass object named spc-test has been created and will be referenced in subsequent pods.
NAME AGE spc-test 20h
- Create a service pod. In this example, this pod is used to run an Nginx application.
- Define a workload, reference the created ServiceAccount object in serviceAccountName, and reference the created SecretProviderClass object in secretProviderClass, specify the mount path of the container in mountPath. (Do not specify special directories such as / and /var/run. Otherwise, the container may fail to be started.)
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-spc labels: app: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: serviceAccountName: nginx-spc-sa # Reference the created ServiceAccount for identity authentication of secrets. volumes: - name: secrets-store-inline csi: driver: secrets-store.csi.k8s.io # Specify the Secrets Store CSI driver. The value is fixed. readOnly: true # Set the volume to read-only to ensure that the secret is not modified. volumeAttributes: secretProviderClass: "spc-test" # Reference the created SPC. containers: - name: nginx-spc image: nginx:alpine imagePullPolicy: IfNotPresent volumeMounts: - name: secrets-store-inline mountPath: "/mnt/secrets-store" # Define the mount path of secrets in the container. readOnly: true imagePullSecrets: - name: default-secret
kubectl apply -f deployment.yaml
Information similar to the following is displayed:deployment/nginx-spc created
- Check whether the pod has been created.
kubectl get pod
If STATUS of the pod is Running in the command output, the pod has been created.
NAME READY STATUS RESTARTS AGE nginx-spc-67c9d5b594-642np 1/1 Running 0 20s
- Check whether the specified secret can be written.
- Enter the container.
kubectl exec -ti nginx-spc-67c9d5b594-642np -- /bin/sh
- Search for the specified secret.
cd /mnt/secrets-store/ ls
If information similar to the following is displayed, secret_1 declared in the SecretProviderClass object has been written to the pod.
secret_1
- Obtain spcPodStatus to check whether the secret has been mounted to the pod.
Exit the container using Ctrl+d and obtain the spcps resource name.
kubectl get spcps
Information similar to the following is displayed:NAME AGE nginx-spc-67c9d5b594-642np-default-spc-test 103s
Check whether the secret has been mounted to the pod.
kubectl get spcps nginx-spc-67c9d5b594-642np-default-spc-test -o yaml
If information similar to the following is displayed, the secret has been mounted to the pod.
...... status: mounted: true objects: # Mounted secret - id: secret_1 version: v1 podName: nginx-spc-67c9d5b594-642np # Pod that references the SecretProviderClass object secretProviderClassName: spc-test # SPC object targetPath: /mnt/paas/kubernetes/kubelet/pods/6dd29596-5b78-44fb-9d4c-a5027c420617/volumes/kubernetes.io~csi/secrets-store-inline/mount
CCE Secrets Manager for DEW must be 1.1.1 or later.
Figure 2 Secrets in DEW
kubectl get sa
- Create a SecretProviderClass.
- Create the secretproviderclass.yaml file using the template below.
apiVersion: secrets-store.csi.x-k8s.io/v1 kind: SecretProviderClass metadata: name: nginx-deployment-spc-k8s-secrets spec: provider: cce parameters: # Reference a secret in CSMS. objects: | - objectName: "secret_1" objectType: "csms" objectVersion: "latest" jmesPath: - path: key1 objectAlias: dbusername01 - path: key2 objectAlias: dbusername02 # Create a CCE secret based on the CSMS secret and mount the secret to a pod. secretObjects: - secretName: my-secret-01 type: Opaque data: - objectName: dbusername01 key: db_username_01 - objectName: dbusername02 key: db_username_02
Table 3 objects parameter Parameter
Type
Mandatory
objectName
String
Yes
Credential name. Set this parameter to the secret referenced in ServiceAccount. If there are multiple object names defined in the same SecretProviderClass, each value of the objectName parameter must be unique. Otherwise, the mounting fails.
objectType
String
Yes
Secret type. Only csms is supported. A value other than csms is invalid.
objectVersion
String
Yes
Secret version
jmesPath
Array of Object
Yes
jmesPath is used to extract key-value pairs from objects in JSON format. CCE Secrets Manager for DEW uses this tool to support secret mounting. If a secret has multiple keys, you need to enter multiple paths and object aliases.
- path: Enter the key in a DEW secret.
The key cannot contain special characters such as +, -, {}, and () for the add-ons of versions earlier than 1.1.57.
In add-ons of version 1.1.57 and later versions, the key cannot contain backslashes (\). There is no restriction on other special characters.
- objectAlias: name of the file mounted to a pod. The value must be the same as the value of objectName defined in secretObjects.
Table 4 secretObjects parameter Parameter
Type
Mandatory
secretName
String
Yes
Secret name
type
String
Yes
Secret type
data
Array of Object
Yes
- objectName: name of the file mounted to the pod. The value must be the same as the value of objectAlias specified in objects.
- key: key in a secret. The value can be used to reference the encrypted content in a pod.
- Run the following command to create a SecretProviderClass object:
secretproviderclass/nginx-deployment-spc-k8s-secrets created
kubectl get spc
NAME AGE nginx-deployment-spc-k8s-secrets 20h
vim deployment.yaml
The file content is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-deployment-k8s-secrets labels: app: nginx-k8s-secrets spec: replicas: 1 selector: matchLabels: app: nginx-k8s-secrets template: metadata: labels: app: nginx-k8s-secrets spec: serviceAccountName: nginx-spc-sa # Reference the created ServiceAccount. containers: - name: nginx-deployment-k8s-secrets image: nginx volumeMounts: # Mount the SecretProviderClass to a container. - name: secrets-store-inline # Name of the volume to be mounted mountPath: "/mnt/secrets" # Path of the container to be mounted readOnly: true env: # Set environment variables so that the container can reference the secret during running. - name: DB_USERNAME_01 # Environment variable name in the workload valueFrom: secretKeyRef: name: my-secret-01 # Secret name specified in the SecretProviderClass key: db_username_01 # The value of the key specified in the SecretProviderClass - name: DB_USERNAME_02 valueFrom: secretKeyRef: name: my-secret-01 key: db_username_02 imagePullSecrets: - name: default-secret volumes: # Use the secret specified in the SPC to create a volume. - name: secrets-store-inline # Custom volume name csi: driver: secrets-store.csi.k8s.io readOnly: true volumeAttributes: secretProviderClass: nginx-deployment-spc-k8s-secrets # Name of the SecretProviderClass created in the previous step
Information similar to the following is displayed:deployment/nginx-deployment-k8s-secrets created
kubectl get pod
NAME READY STATUS RESTARTS AGE nginx-deployment-k8s-secrets-6c945565fb-s7smv 1/1 Running 0 20s
- Verify the result.
kubectl get secrets
The output shows that a secret named my-secret-01 has been created using secret_1 specified in the SecretProviderClass object.
NAME TYPE DATA AGE default-secret kubernetes.io/dockerconfigjson 1 33d my-secret-01 Opaque 2 1h
Scheduled Rotation
As described before, you can use this add-on to complete the mount secrets, that is, you can write the secrets stored in CSMS to a pod.
To change the secret version declared in the SPC object to latest, run the following command:
provider: cce
parameters:
objects: |
objectVersion: "latest" # change "v1"to "latest"
objectType: "csms"
After the SPC object is updated, the add-on periodically sends a request to CSMS to obtain the value of secret_1 of the latest version and updates the value to the pod that references the SPC object. The interval for the add-on to periodically send requests is specified by rotation_poll_interval set in Installing the Add-on.
Real-Time Detection of SPC Changes
SPC changes are already detected in real time in Mounting a Credential Using a Volume and Scheduled Rotation. For demonstration, add secret secret_2 to the SPC object as follows:
apiVersion: secrets-store.csi.x-k8s.io/v1 kind: SecretProviderClass metadata: name: spc-test spec: provider: cce parameters: objects: | - objectName: "secret_1" objectVersion: "latest" objectType: "csms" - objectName: "secret_2" objectVersion: "v1" objectType: "csms"
After the SPC object is updated, the new secret_2 is quickly mounted to the pod that references the SPC object.
Viewing Component Logs
You can use kubectl to view component logs.
- View the pods for running the add-on.
kubectl get pod -n kube-system
NAME READY STATUS RESTARTS AGE csi-secrets-store-76tj2 3/3 Running 0 11h dew-provider-hm5fq 1/1 Running 0 11h
- View the logs of the dew-provider component.
kubectl logs dew-provider-hm5fq -n kube-system
The command output is the detailed log information.
... I0321 13:49:29.319708 1 dew_provider.go:43] object [secret_1]'s version [v1] doesn't change, read from local I0321 13:49:29.319735 1 server.go:108] Start writing into mount point I0321 13:49:29.319793 1 server.go:117] Write [secret_1/]'s value into file successfully I0321 13:49:29.319801 1 server.go:123] Write secret file finished I0321 13:49:29.320284 1 server.go:67] "Servicing mount request" Pod="nginx-deployment-k8s-secrets-6c945565fb-s7smv" Namespace="default" ServiceAccount="nginx-spc-sa" I0321 13:49:29.617666 1 dew_provider.go:107] "Get secret successfully" name="secret_1" version="v1" ...
- View the logs of the csi-secrets-store component. The pod of the csi-secrets-store component contains multiple containers. When viewing logs, run the -c command to specify a container. The secrets-store container is the major service container of the add-on and contains the majority of the logs.
kubectl logs csi-secrets-store-76tj2 -c secrets-store -n kube-system
... I0321 10:17:29.314888 1 secrets-store.go:46] "Initializing Secrets Store CSI Driver" driver="secrets-store.csi.k8s.io" version="local-dev" buildTime="" I0321 10:17:29.314987 1 reconciler.go:143] "starting rotation reconciler" rotationPollInterval="2m0s" I0321 10:17:29.315141 1 server.go:126] "Listening for connections" address="//mnt/paas/kubernetes/kubelet/plugins/csi.sock" I0321 10:17:30.933328 1 nodeserver.go:359] "node: getting default node info\n" I0321 10:19:19.269337 1 nodeserver.go:353] "Using gRPC client" provider="cce" pod="nginx-spc-744b4c57dc-x74xq" I0321 10:19:19.543221 1 secretproviderclasspodstatus_controller.go:224] "reconcile started" spcps="default/nginx-spc-744b4c57dc-x74xq-default-spc-test" ...
Release History
Add-on Version |
Supported Cluster Version |
New Feature |
1.1.75 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
CCE clusters v1.32 are supported. |
1.1.60 |
v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
Fixed some issues. |
1.1.57 |
CCE clusters v1.31 are supported. |
1.1.33 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 |
CCE clusters v1.30 are supported. |
1.1.3 |
v1.21 v1.23 v1.25 v1.27 v1.28 v1.29 |
1.1.2 |
1.0.31 |
v1.21 v1.23 v1.25 v1.27 v1.28 |
1.0.9 |
v1.19 v1.21 v1.23 v1.25 |
None |
1.0.6 |
None |
1.0.3 |
CCE clusters v1.25 are supported. |
1.0.2 |
v1.19 v1.21 v1.23 |
CCE clusters v1.23 are supported. |
1.0.1 |
v1.19 v1.21 |
Supported active detection of changes on the SecretProviderClass objects. |
