CPU Policy
Applications
By default, kubelet uses CFS quotas to enforce pod CPU limits. When a node runs many CPU-bound pods, the workload can move to different CPU cores depending on whether the pod is throttled and which CPU cores are available at scheduling time. Many workloads are not sensitive to this migration and work fine without any intervention. Some applications are CPU-sensitive. They are sensitive to:
- CPU throttling
- Context switching
- Processor cache misses
- Cross-socket memory access
- Hyperthreads that are expected to run on the same physical CPU card
If your workloads are sensitive to any of these items, you can use Kubernetes CPU management policies to allocate dedicated CPU cores (through CPU pinning) to these workloads. This will shorten scheduling latency and improve application performance. The CPU manager preferentially allocates resources on a socket and full physical cores to avoid interference.
A CPU management policy is specified by using kubelet --cpu-manager-policy. By default, Kubernetes supports the following policies:
- none: the default policy. The none policy explicitly enables the existing default CPU affinity scheme, providing no affinity beyond what the OS scheduler does automatically.
- static: The static policy allows containers in guaranteed pods with integer CPU requests to use dedicated CPU resources on nodes through CPU pinning.
Notes and Constraints
- The CPU management policy does not apply to ECS (PM) nodes in CCE Turbo clusters.
- In clusters v1.34 or later, static CPU management policies are incompatible with pod-level resource requests or limits (configured via Pod-level specification for resources).
Configuring a CPU Management Policy
You can use either of the following ways.
When creating a cluster, you can enable CPU management in the Advanced Settings area. This setting applies to the entire cluster, and cluster-level CPU management policies cannot be modified after the cluster creation. If CPU management is not enabled during cluster creation, the nodes in DefaultPool will not support changes to CPU management policies. To apply CPU management policies, you must create a custom node pool and configure the desired settings for its nodes.
- If this function is enabled, the static Kubernetes policy is used, where CPU pinning is used.
- If this function is disabled, the none Kubernetes policy is used, where CPU pinning is not used.
You can configure a CPU management policy for a custom node pool. After the configuration, the kubelet parameter --cpu-manager-policy will be automatically modified on the nodes in the node pool.
The default node pool (DefaultPool) adheres to the cluster-level CPU management policies, and its CPU management policies cannot be modified.
- Choose Nodes in the navigation pane and click the Node Pools tab on the right. Locate the target node pool and choose More > Manage.
- On the Manage Configurations page, set CPU Management Policy (cpu-manager-policy) to static in the kubelet area.
- Click OK.
Allowing Pods to Exclusively Use the CPU Resources
Prerequisites:
- Enable the static policy on the node. For details, see Configuring a Cluster-level CPU Management Policy (Nodes in DefaultPool Supported).
- Both requests and limits must be configured in pods and their values must be the same integer.
You can use node affinity scheduling to schedule the configured pods to the nodes where the static policy is enabled. In this way, the pods can exclusively use the CPU resources.
kind: Deployment
apiVersion: apps/v1
replicas: 1
selector:
matchLabels:
app: test
template:
labels:
app: test
containers:
- name: container-1
image: nginx:alpine
resources:
requests:
cpu: 2 # The value must be an integer and must be the same as that in limits.
memory: 2048Mi
limits:
cpu: 2 # The value must be an integer and must be the same as that in requests.
memory: 2048Mi
imagePullSecrets:
- name: default-secret Verification
Take a node with 8 vCPUs and 16 GiB of memory as an example. Deploy a workload whose CPU request and limit are both 2 on the node beforehand.
cat /var/lib/kubelet/cpu_manager_state
Command output:
{"policyName":"static","defaultCpuSet":"0-1,4-7","entries":{"de14506d-0408-411f-bbb9-822866b58ae2":{"container-1":"2-3"}},"checksum":3744493798} - If the policyName is static, the policy has been configured.
- Value 2-3 indicates the set of CPUs that can be used by containers in the pod.
