Updated on 2026-09-21 GMT+08:00
Automatically Creating an SFS Volume Through kubectl
Currently, SFS file systems are sold out and PVCs cannot be automatically created using the storage class.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following commands to configure the pvc-sfs-auto-example.yaml file, which is used to create a PVC.
    touch pvc-sfs-auto-example.yaml
    vi pvc-sfs-auto-example.yaml
    Example YAML file:
    apiVersion: v1
    kind: PersistentVolumeClaim
      annotations:
        volume.beta.kubernetes.io/storage-class: nfs-rw
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 10Gi
    Table 1 Key parameters
    File storage class. Currently, the standard file protocol type (nfs-rw) is supported.
    name
    Name of the PVC to be created.
    accessModes
    Only ReadWriteMany is supported. ReadWriteOnce is not supported.
    storage
    Storage capacity, in Gi.
  3. Run the following command to create a PVC:
    kubectl create -f pvc-sfs-auto-example.yaml
    After the command is executed, a file system is created in the VPC to which the cluster belongs. Choose Storage > SFS on the CCE console or log in to the SFS console to view the file system.
