Help Center/ Cloud Container Engine/ User Guide/ Nodes/ Management Nodes/ Performing a Rolling Upgrade for Nodes
Updated on 2026-06-16 GMT+08:00
In a rolling upgrade, a new node is created, existing workloads are migrated to the new node, and then the old node is deleted. Figure 1 shows the migration process.
Figure 1 Workload migration
  • The original node and the target node to which the workload is to be migrated must be in the same cluster.
  • The cluster must be of Kubernetes v1.13.10 or later.
  • The default node pool (DefaultPool) cannot be modified.
Procedure If the Original Node Is in the Default Pool
  1. Create a node pool. For details, see Creating a Node Pool.
  2. On the node pool list page, click View Node in the Operation column of the target node pool. The IP address of the new node is displayed in the node list.
  1. Install and configure kubectl. For details, see Accessing a Cluster Using kubectl.
  1. Migrate the workload.
    1. Add a taint to the node where the workload needs to be migrated out.
      kubectl taint node <node-name> <key>=<value>:<effect>
      <node-name> is the IP address of the node where the current workload runs. <key> is the taint key. <value> is the taint value. <effect> options include NoSchedule, PreferNoSchedule, and NoExecute. In this example, it must be set to NoSchedule.
      • NoSchedule: Pods that do not tolerate this taint are not scheduled on the node; existing pods are not evicted from the node.
      • PreferNoSchedule: Kubernetes tries to avoid scheduling pods that do not tolerate this taint onto the node.
      • NoExecute: A pod is evicted from the node if it is already running on the node, and is not scheduled onto the node if it is not yet running on the node.
      To delete a specific taint, run the following command:
      kubectl taint node <node-name> <key>:<effect> -
    2. Drain the node safely.
      kubectl drain <node>
      In this command, <node> indicates the IP address of the node where the workload to be migrated is located.
    3. In the navigation pane of the CCE console, choose Workloads > Deployments. In the workload list, the status of the workload to be migrated changes from Running to Unready. If the workload status changes to Running again, the migration is successful.
    During workload migration, if node affinity is configured for the workload, the workload keeps displaying a message indicating that the workload is not ready. In this case, click the workload name to go to the workload details page. On the Scheduling Policies tab page, delete the affinity configuration of the original node and configure the affinity and anti-affinity policies of the new node. For details, see Configuring Node Affinity Scheduling (nodeAffinity).
    After the workload is migrated, you can view that the workload has been migrated to the node created in 1 on the Pods tab of the workload details page.
  1. Delete the original node.
    After the workload is successfully migrated and runs properly, delete the original node.
Procedure If the Original Node Is Not in the Default Pool
  1. Copy the node pool and add a node to it. For details, see Copying a Node Pool.
  2. Click View Node in the Operation column of the node pool. The IP address of the new node is displayed in the node list.
    1. Click Edit on the right of original node pool and configure Taints.
    2. Enter the key and value of a taint. The options of Effect are NoSchedule, PreferNoSchedule, and NoExecute. Select NoExecute and click Add.
      To reset the taint, delete the configured one.
    3. Click OK.
    4. In the navigation pane of the CCE console, choose Workloads > Deployments. In the workload list, the status of the workload to be migrated changes from Running to Unready. If the workload status changes to Running again, the migration is successful.
