Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration
In a CCE Turbo cluster, you can configure pod subnets and security groups for containers by namespace or workload using NetworkAttachmentDefinition CRDs. To configure a particular pod subnet and security group for a specified namespace or workload, create a container network configuration (NetworkAttachmentDefinition) and associate it with the target namespace or workload. In this way, service subnets can be planned or services can be securely isolated.
Security groups can be associated with workloads through multiple methods: annotations, security group policies, node pool settings, or pod network settings. When multiple methods are used, only the highest-priority method applies. For details about priorities, see Comparison of Workload Security Group Configuration Methods.
| Category | Resources a Container Network Configuration Can Associate with | |
| Namespace | Workload | |
| Subnet and security group configurations | All workloads in a namespace that is associated with a container network configuration will share the same subnet and security group. | Workloads sharing a container network configuration use the same subnet and security group. |
| Supported cluster versions | Available only in CCE Turbo clusters of 1.23.8-r0, 1.25.3-r0, or later. | Available only in CCE Turbo clusters v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later. |
| Constraints | A namespace can be associated with only one container network configuration. | Only the custom container network configurations that are not associated with any namespace can be specified. |
- If default-network is available in a cluster, it takes effect on all pods where no custom container network configuration has been configured. The default pod subnet in the network settings on the Overview page is the pod subnet in default-network. default-network cannot be deleted. When using kubectl, only the securityGroups field may be modified. Changes to other fields may result in configuration loss or corruption.
- If there is only one container network configuration in a cluster, it is the default container network configuration. If there are multiple container network configurations in a cluster, the one with annotation yangtse.io/default-network: true is the default container network configuration. If there is no default container network configuration in a cluster, the pod that is not associated with any container network configuration fails to be start after being created because no network interface can be allocated for the pod.
- Only the default container network configuration supports dynamic pre-binding of container network interfaces. When the quota of node network interfaces is used up, the pod that uses the custom container network configuration attempts to unbind the pre-bound network interface of the default container network configuration, leading to slower pod startup. Therefore, if you need to frequently use the custom container network configuration, disable dynamic pre-binding of global container network interfaces in the target cluster. If you require high-speed pod elasticity using the default pod network configuration, properly plan dynamic pre-binding of pod network interfaces in the target node pool based on your scheduling requirements.
- If a workload with a fixed IP address needs to be associated with a new container network configuration, the fixed IP address will be invalid when pods are rebuilt. In this case, delete the workload, release the fixed IP address, and create a workload again.
- Before deleting a custom container network configuration, delete the pods (with the cni.yangtse.io/network-status annotation) created using the configuration in the target namespace. For details, see Deleting a Container Network Configuration.
- When you add a new subnet to the default network, a security group rule is automatically added to the node security group in the inbound direction, allowing the CIDR block of that subnet. To avoid any issues, make sure that the node security group can handle more security group rules than the number of new subnets you plan to add. If there are not enough security group quotas, you can submit a service ticket to increase the quota.
- When a subnet is added to a container network configuration, the VPC API /v2.0/subnets is called twice. The first call checks if the subnet is available, while the second call retrieves subnet information for persistence by the control plane components. Do not add more than 20 subnets at a time. Otherwise, the traffic control will be triggered for the VPC API.
- Pod network settings cannot be created via the console for distributed CCE Turbo clusters. Use kubectl commands instead.
Creating a Container Network Configuration of the Namespace Type
After such a container network configuration is created and associated with a namespace, all workloads created in the namespace will use the same subnet and security group.
- Choose Settings in the navigation pane and click the Network tab.
- Locate the Container Network area and click Add. In the Create Network Configurations dialog box, configure parameters such as the pod subnet and security group.
- Name: Enter a name that contains a maximum of 63 characters. Do not use default-network, default, mgnt0, or mgnt1.
- Associated Resource Type: resource type associated with the custom container network configuration. For details, see Table 1. To create a container network configuration of the namespace type, select Namespace.
- Namespace: Select the namespace to be associated. The namespaces associated with different container network configurations must be unique. If no namespace is available, click Create Namespace to create one.
- Pod Subnet: Select a subnet. If no subnet is available, click Create Subnet to create one. After the subnet is created, click the refresh button. A maximum of 20 subnets can be selected for clusters earlier than v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.29.8-r0, v1.30.4-r0, or v1.28.13-r0. A maximum of 100 subnets can be selected for clusters v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later.
- Associate Security Group: The default value is the container ENI security group. You can also click Create Security Group to create one. After the security group is created, click the refresh button. For better network performance, select no more than five security groups.
Figure 2 Creating a container network configuration of the namespace type
- Click OK. After the creation, you will be redirected to the custom container network configuration list, where the new container network configuration is included. Figure 3 Container network configuration list
This section describes how to use kubectl to create a container network configuration of the namespace type.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Modify the networkattachment-test.yaml file.
vi networkattachment-test.yaml
Example file content:
apiVersion: k8s.cni.cncf.io/v1 kind: NetworkAttachmentDefinition metadata: annotations: yangtse.io/project-id: 05e38** name: example namespace: kube-system spec: config: | { "type":"eni-neutron", "args":{ "securityGroups":"41891**", "subnets":[ { "subnetID":"27d95**" } ] }, "selector":{ "namespaceSelector":{ "matchLabels":{ "kubernetes.io/metadata.name":"default" } } } }Table 2 Key parameters Parameter
Mandatory
Type
apiVersion
Yes
String
API version. The value is fixed at k8s.cni.cncf.io/v1.
kind
Yes
String
Type of the object to be created. The value is fixed at NetworkAttachmentDefinition.
Yes
String
Project ID in the current region. For details, see Obtaining a Project ID.
name
Yes
String
Configuration item name.
namespace
Yes
String
Namespace of the configuration resource. The value is fixed to kube-system.
config
Yes
config Object
Configuration content, which is a string in JSON format.
Table 3 config parameters Parameter
Mandatory
Type
type
Yes
String
The value is fixed at eni-neutron.
args
No
args Object
Configuration parameters.
selector
No
selector Object
Namespace in which the configuration takes effect.
Table 4 args parameters Parameter
Mandatory
Type
securityGroups
No
String
Security group ID. If no security group is planned, ensure that the security group is the same as that in default-network.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Access Control > Security Groups. Click the target security group name and copy the ID on the Summary tab page.
subnets
Yes
Array of subnets Objects
List of pod subnet IDs. At least one subnet ID is required.
Table 5 subnets data structure Parameter
Mandatory
Type
subnetID
Yes
String
Subnet ID in the same VPC.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Virtual Private Cloud > Subnets. Click the target subnet name and copy the Subnet ID on the Summary tab page.
publicBorderGroup
No
String
This parameter is only used in distributed CCE Turbo clusters to specify the edge AZ name.
Table 6 selector parameters Parameter
Mandatory
Type
namespaceSelector
No
matchLabels object
A Kubernetes standard selector. Enter the namespace label in the following format:
"matchLabels":{ "kubernetes.io/metadata.name":"default" }The namespaces of different configurations cannot overlap.
- Create a NetworkAttachmentDefinition.
kubectl create -f networkattachment-test.yaml
If information similar to the following is displayed, the configuration has been created:
networkattachmentdefinition.k8s.cni.cncf.io/example created
Creating a Container Network Configuration of the Workload Type
- Associated Resource Type: resource type associated with the custom container network configuration. For details, see Table 1. To create a container network configuration of the workload type, select Workload.
Figure 4 Creating a container network configuration of the workload type
- Click OK. After the creation, you will be redirected to the custom container network configuration list, where the new container network configuration is included. Figure 5 Container network configuration list
- When creating a workload, you can select a custom container network configuration.
- Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
- Click Create Workload in the upper right corner of the page. In the Advanced Settings area, choose Network Configuration and determine whether to enable a specified container network configuration.
- Select an existing container network configuration. If no configuration is available, click Add to create one. Figure 6 Selecting a container network configuration
- After the configuration, click Create Workload.
Return to the Settings page. In the container network configuration list, the name of the resource associated with the created container network configuration is displayed.
Figure 7 Resource associated with a container network configuration
This section describes how to use kubectl to create a container network configuration of the workload type.
apiVersion: k8s.cni.cncf.io/v1 kind: NetworkAttachmentDefinition metadata: annotations: yangtse.io/project-id: 80d5a** name: example namespace: kube-system spec: config: | { "type":"eni-neutron", "args":{ "securityGroups":"f4983**", "subnets":[ { "subnetID":"5594b**" } ] } }Table 7 Key parameters Parameter
Mandatory
Type
apiVersion
Yes
String
kind
Yes
String
Yes
String
name
Yes
String
namespace
Yes
String
config
Yes
config Object
Table 8 config parameters Parameter
Mandatory
Type
type
Yes
String
args
No
args Object
Table 9 args parameters Parameter
Mandatory
Type
securityGroups
No
String
How to obtain:
subnets
Yes
Table 10 subnets data structure Parameter
Mandatory
Type
subnetID
Yes
String
How to obtain:
publicBorderGroup
No
String
- Create a Deployment workload and associate it with the newly created container network configuration.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx yangtse.io/network: "example" # Name of the custom container network configuration, which can be used to obtain all pods associated with the container network configuration by label annotations: yangtse.io/network: "example" # Name of the custom container network configuration spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret- yangtse.io/network: name of the specified custom container network configuration. Only a container network configuration that is not associated with any namespace can be specified. Add this parameter to the label so that you can use the label to obtain all pods associated with this container network configuration.
Verify That a Container Network Configuration Is Associated with a Namespace or Workload
Verify that a subnet and security group specified in the container network configuration have been associated with a workload. To check if a namespace is associated with a container network configuration, check whether a workload in the namespace is associated with a subnet and security group.
- Verify that a subnet is associated.
- Check the IP address of a pod for a workload.
kubectl get pod -o wide
Information similar to the following is displayed:
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES nginx-85dbdb8c5d-ng5bb 1/1 Running 0 5d18h 192.168.60.5 ca50a5ae-e1ef-41c6-b3fc-6ebcd10a1e07 <none> <none>
- Log in to the VPC console. In the navigation pane, choose Virtual Private Cloud > Subnets and click the target subnet name.
- Click IP Addresses. If the IP address of the pod is displayed, the subnet is associated. Figure 8 Viewing the IP address associated with a pod
- Verify that a security group is associated.
- Switch back to the VPC console. In the navigation pane, choose Access Control > Security Groups and click the target security group name.
- On the Associated Instances tab, click Supplementary Network Interfaces.
- View the private IP address of the pod in the Private IP Address column. If the private IP address of the pod is displayed, the security group is associated with it. Figure 9 Viewing the IP address associated with a security group
You can delete the new container network configuration or view its YAML file.
Before deleting a container network configuration, delete all pods using the configuration. Otherwise, the deletion will fail.
- Run the following command to filter the pods that use the configuration in the cluster (example is used as a placeholder):
kubectl get pod -A -o=jsonpath="{range .items[?(@.metadata.annotations.cni\\.yangtse\\.io/network-status=='[{\"name\":\"example\"}]')]}{.metadata.namespace}{'\t'}{.metadata.name}{'\n'}{end}"The command output contains the pod name and namespace associated with the configuration.
- Delete the owner of the pod. The owner may be a Deployment, StatefulSet, DaemonSet, or Job.
