Updated on 2025-08-19 GMT+08:00
Enabling ICMP Security Group Rules
If a workload uses UDP for both load balancing and health check, enable ICMP security group rules for the backend servers. For details, see How Does ELB Perform UDP Health Checks? What Are the Precautions for UDP Health Checks?
  1. Log in to the VPC console and choose Access Control > Security Groups.
  2. In the security group list, locate the security group of the cluster. Click the Inbound Rules tab page and then Add Rule. In the Add Inbound Rule dialog box, configure inbound parameters.
    Cluster Type
    ELB Type
    Security Group
    Protocol & Port
    Allowed Source CIDR Block
    CCE Standard
    Shared
    Node security group, which is named in the format of "{Cluster name}-cce-node-{Random ID}".
    If a custom node security group is bound to the cluster, select the target security group.
    All ICMP ports
    100.125.0.0/16 for the shared load balancer
    Dedicated
    All ICMP ports
    Backend subnet of the load balancer
    CCE Turbo
    Shared
    All ICMP ports
    Dedicated
    ENI security group, which is named in the format of "{Cluster name}-cce-eni-{Random ID}".
    If a custom ENI security group is bound to the cluster, select the target security group.
    All ICMP ports
    Figure 1 Adding a security group rule
  3. Click OK.
