Help Center/ Cloud Container Engine/ User Guide/ Workloads/ Logging In to a Container
Updated on 2026-06-16 GMT+08:00
If you encounter unexpected problems when using a container, you can log in to the container to debug it.
  • When kubectl is used in CloudShell, permissions are determined by the logged-in user.
  • CloudShell does not support an account or sub-project agency.
  • When using CloudShell to access a CCE cluster or container, you can open up to 15 instances concurrently.
  • The kubectl certificate in CloudShell is valid for one day. You can reset its validity period by accessing CloudShell through the CCE console.
  • CloudShell is not available in some regions. You can check the available regions on the console.
Using CloudShell
CloudShell is implemented based on VPC Endpoint (VPCEP). To use kubectl to access a cluster, configure the security group (Cluster name-cce-control-Random number) on the master node of the cluster to allow access to port 5443. By default, port 5443 allows access from all CIDR blocks. If you have hardened security groups and any cluster cannot be accessed in CloudShell, check whether port 5443 allows access from 198.19.0.0/16.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. In the navigation pane, choose Workloads. In the right pane, click the name of the target workload to view its pods.
  3. Locate the target pod and choose More > Remote Login in the Operation column.
    Figure 1 Accessing a container
  4. In the displayed dialog box, select the container you want to access and the command, and click OK.
    Figure 2 Selecting a container and login command
    You are automatically redirected to CloudShell, where kubectl is initialized and the kubectl exec command is executed to log in to the container.
    Wait for 5 to 10 seconds until the kubectl exec command is automatically executed.
    Figure 3 CloudShell page
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following command to view the created pod:
    kubectl get pod
    The example output is as follows:
    NAME                               READY   STATUS    RESTARTS       AGE
    nginx-59d89cb66f-mhljr             1/1     Running   0              11m
  3. Query the container name in the pod.
    kubectl get po nginx-59d89cb66f-mhljr -o jsonpath='{range .spec.containers[*]}{.name}{end}{"\n"}'
    container-1
  4. Run the following command to log in to the container-1 container in the nginx-59d89cb66f-mhljr pod:
    kubectl exec -it nginx-59d89cb66f-mhljr -c container-1 -- /bin/sh
    If a command prompt similar to / # or root@<container_id>:/ # is displayed, you have logged in to the container.
  5. To exit the container, run the exit command.
Helpful Links
