CCE Operations Supported by CTS
Cloud Trace Service (CTS) records operations on cloud service resources, allowing you to query, audit, and backtrack the resource operation requests initiated from the CCE console or open APIs as well as responses to the requests.
To collect the query events (Get and List) listed in the table below, enable read-only event reporting of CCE in CTS. Because query operations occur far more frequently than addition, deletion, or modification operations, enabling this function may generate a large number of events. Assess the potential impacts before enabling it.
| Operation | Resource | Trace Name |
| Creating an agency | Cluster | createUserAgencies |
| Querying an agency | Cluster | getUserAgencies |
| Obtaining an access policy | Cluster | getAccessPolicy |
| Creating an access policy | Cluster | createAccessPolicy |
| Deleting an access policy | Cluster | deleteAccessPolicy |
| Obtaining the access policy list | Cluster | listAccessPolicy |
| Updating an access policy | Cluster | updateAccessPolicy |
| Creating a cluster | Cluster | createCluster |
| Creating a yearly/monthly cluster | Cluster | createCluster/createPeriodicCluster |
| Updating the description of a cluster | Cluster | updateCluster |
| Upgrading a cluster | Cluster | clusterUpgrade |
| Deleting a cluster | Cluster | claimCluster/deleteCluster |
| Obtaining the cluster list | Cluster | listCluster |
| Obtaining the cluster list in a project | Cluster | getClustersByProjectID |
| Obtaining the number of clusters | Cluster | getClusterInstances |
| Obtaining a cluster | Cluster | getClusterByUID |
| Obtaining the cluster package list | Cluster | getPackageLists |
| Obtaining the package configuration of a cluster | Cluster | getPackageConfigs |
| Downloading a cluster certificate | Cluster | getClusterCertByUID |
| Revoking a cluster certificate | Cluster | revokeClusterCert |
| Binding and unbinding an EIP | Cluster | operateMasterEIP |
| Waking up a cluster and resetting node management (V2) | Cluster | operateCluster |
| Hibernating a cluster (V3) | Cluster | hibernateCluster |
| Waking up a cluster (V3) | Cluster | awakeCluster |
| Changing the size of a pay-per-use cluster | Cluster | resizeCluster |
| Changing the size of a yearly/monthly cluster | Cluster | resizePeriodCluster |
| Modifying configurations of a cluster | Cluster | updateConfiguration |
| Obtaining cluster configuration | Cluster | getClusterConfiguration |
| Obtaining all configurations of the current cluster version | Cluster | getClusterConfigurationDetail |
| Querying the detailed configuration items of a cluster by cluster version or type | Cluster | getClusterSupportConfiguration |
| Obtaining cluster quotas | Cluster | getQuotas |
| Obtaining the global OBS access secret configuration of a cluster | Cluster | getClusterLongAKSKConfig |
| Updating the global OBS access secret configuration of a cluster | Cluster | updateClusterLongAKSKConfig |
| Updating the global OBS access secret configuration in a project | Cluster | UpdateAKSKConfig |
| Obtaining the global OBS access secret configuration in a project | Cluster | GetAKSKConfig |
| Obtaining the IP address of a master node | Cluster | GetOpenAPIInfo |
| Obtaining the cluster access address | Cluster | GetEndpoints |
| Changing the billing mode of a cluster from pay-per-use to yearly/monthly | Cluster | ChangeBillingModeToPeriod |
| Retrying a cluster upgrade | Cluster | ClusterUpgradeRetry |
| Pausing a cluster upgrade | Cluster | ClusterUpgradePause |
| Continuing a cluster upgrade | Cluster | ClusterUpgradeContinue |
| Rolling back a cluster upon an upgrade failure | Cluster | Rollback |
| Rolling back a cluster upon an upgrade retry failure | Cluster | ClusterRollbackRetry |
| Pausing a cluster upgrade rollback | Cluster | ClusterRollbackPause |
| Continuing a cluster upgrade rollback | Cluster | ClusterRollbackContinue |
| Querying the cluster rollback history | Cluster | GetRollbackTasks |
| Querying the cluster upgrade history | Cluster | GetUpgradeTasks |
| Querying the records of a cluster upgrade | Cluster | GetUpgradeTask |
| Querying cluster labels | Cluster | GetLabels |
| Querying the configuration of a cluster | Cluster | GetUpgradeInfo |
| Obtaining the certificate rotation state | Cluster | GetRotationState |
| Rotating certificates | Cluster | RotateCredentials |
| Downloading certificates | Cluster | DownloadNodeCredentials |
| Rolling back certificates | Cluster | RollbackCredentials |
| Completing certificate rotation | Cluster | FinishEncryptionKeyRotation |
| Supplementing the component certificates of a master node | Cluster | CompleteComponentCredential |
| Updating cluster certificates | Cluster | RotateClusterCredentials |
| Enabling the cluster upgrade workflow booting task | Cluster | UpgradeWorkFlow |
| Querying cluster upgrade workflows | Cluster | GetUpgradeWorkFlows |
| Querying details about a cluster upgrade task | Cluster | UpgradeWorkFlowUpdate |
| Performing a pre-upgrade check for a cluster | Cluster | PreCheck |
| Obtaining the list of historical check records | Cluster | GetPreCheckList |
| Obtaining a specific check record | Cluster | GetPreCheck |
| Performing a post-upgrade check | Cluster | PostCheck |
| Performing a rolling upgrade on the cluster control plane | Cluster | RollingUpdateControlPlane |
| Retrying a rolling upgrade on the cluster control plane | Cluster | RetryRollingUpdateControlPlane |
| Creating a node pool | Node pool | createNodePool |
| Updating a node pool | Node pool | updateNodePool |
| Deleting a node pool | Node pool | claimNodePool |
| Migrating a node pool | Node pool | migrateNodepool |
| Updating the node pool configuration | Node pool | updateConfiguration |
| Obtaining the node pool configuration | Node pool | getConfiguration |
| Obtaining node pool details | Node pool | getConfigurationDetail |
| Querying a node pool | Node pool | getNodePool |
| Querying the node pool quota | Node pool | getNodePoolQuota |
| Querying all node pools in a cluster | Node pool | listNodePools |
| Scaling up a yearly/monthly node pool | Node pool | scalePeriodicNodePool |
| Scaling down a node pool | Node pool | scaleNodePool |
| Upgrading a node pool | Node pool | upgradeNodePool |
| Adding nodes | Node | addNodes |
| Creating a node | Node | createNode |
| Creating a yearly/monthly node | Node | createPeriodNode |
| Deleting all nodes from a cluster | Node | deleteAllHosts |
| Deleting a node | Node | deleteOneHost/claimOneHost |
| Updating the description of a node | Node | updateNode |
| Obtaining the list of nodes in a cluster | Node | getHostsList |
| Obtaining a node | Node | getOneHost |
| Changing the node billing mode from pay-per-use to yearly/monthly | Node | changeNodeBillingModeToPeriod |
| Removing nodes | Node | removeNodesTask |
| Resetting nodes | Node | resetNodes |
| Migrating nodes to the node pool | Node | MigrateNodes |
| Synchronizing nodes in a batch | Node | SyncNodes |
| Migrating nodes | Node | MigrateNodesTask |
| Locking a node pool so that it will not be scaled down | Node | LockNodepoolNodeScaleDown |
| Unlocking a node pool so that it can be scaled down | Node | UnLockNodepoolNodeScaleDown |
| Deleting all jobs | Job | deleteJobs |
| Deleting a job | Job | deleteOneJob |
| Obtaining jobs in a project | Job | getJobsByProjectID |
| Obtaining a job | Job | getJobByUID |
| Creating an add-on pod | Add-on pod | createAddonInstance |
| Querying an add-on pod | Add-on pod | getAddonInstance |
| Deleting an add-on pod | Add-on pod | deleteAddonInstance |
| Obtaining the add-on list | Add-on pod | getAddonsList |
| Updating an add-on pod | Add-on pod | updateAddonInstance |
| Rolling back an add-on pod | Add-on pod | rollbackAddonInstance |
| Obtaining add-on details by add-on ID | Add-on pod | GetAddonTemplate |
| Obtaining the add-on template list | Add-on pod | GetAddonTemplateList |
| Uploading a chart | Chart | uploadChart |
| Updating a chart | Chart | updateChart |
| Deleting a chart | Chart | deleteChart |
| Downloading a chart | Chart | downloadChart |
| Querying a chart | Chart | getChart |
| Obtaining chart details | Chart | getChartValues |
| Obtaining the chart list | Chart | listCharts |
| Obtaining the chart quota | Chart | getUserChartsQuotas |
| Creating a release | Release | createRelease |
| Upgrading a release | Release | updateRelease |
| Deleting a release | Release | deleteRelease |
| Querying a release | Release | getRelease |
| Querying the release history | Release | getReleaseHistory |
| Querying the release list | Release | listReleases |
| Creating a ConfigMap | Kubernetes resource | createConfigmaps |
| Querying a ConfigMap | Kubernetes resource | getConfigmaps |
| Creating a DaemonSet | Kubernetes resource | createDaemonsets |
| Querying a DaemonSet | Kubernetes resource | getDaemonsets |
| Creating a Deployment | Kubernetes resource | createDeployments |
| Querying a Deployment | Kubernetes resource | getDeployments |
| Creating an event | Kubernetes resource | createEvents |
| Querying an event | Kubernetes resource | getEvents |
| Creating an ingress | Kubernetes resource | createIngresses |
| Querying an ingress | Kubernetes resource | getIngresses |
| Creating a job | Kubernetes resource | createJobs |
| Querying a job | Kubernetes resource | getJobs |
| Creating a namespace | Kubernetes resource | createNamespaces |
| Querying a namespace | Kubernetes resource | getNamespaces |
| Creating a node | Kubernetes resource | createNodes |
| Querying a node | Kubernetes resource | getNodes |
| Creating a PersistentVolumeClaim | Kubernetes resource | createPersistentvolumeclaims |
| Querying a PersistentVolumeClaim | Kubernetes resource | getPersistentvolumeclaims |
| Creating a pod | Kubernetes resource | createPods |
| Querying a pod | Kubernetes resource | getPods |
| Creating a ReplicaSet | Kubernetes resource | createReplicasets |
| Querying a ReplicaSet | Kubernetes resource | getReplicasets |
| Creating a resource quota | Kubernetes resource | createResourcequotas |
| Creating a secret | Kubernetes resource | createSecrets |
| Querying a secret | Kubernetes resource | getSecrets |
| Creating a Service | Kubernetes resource | createServices |
| Querying a Service | Kubernetes resource | getServices |
| Creating a StatefulSet | Kubernetes resource | createStatefulsets |
| Querying a StatefulSet | Kubernetes resource | getStatefulsets |
| Creating a volume | Kubernetes resource | createVolumes |
| Querying a volume | Kubernetes resource | getVolumes |
| Deleting a ConfigMap | Kubernetes resource | deleteConfigmaps |
| Deleting a DaemonSet | Kubernetes resource | deleteDaemonsets |
| Deleting a Deployment | Kubernetes resource | deleteDeployments |
| Deleting an event | Kubernetes resource | deleteEvents |
| Deleting an ingress | Kubernetes resource | deleteIngresses |
| Deleting a job | Kubernetes resource | deleteJobs |
| Deleting a namespace | Kubernetes resource | deleteNamespaces |
| Deleting a node | Kubernetes resource | deleteNodes |
| Deleting a Pod | Kubernetes resource | deletePods |
| Deleting a ReplicaSet | Kubernetes resource | deleteReplicasets |
| Deleting a resource quota | Kubernetes resource | deleteResourcequotas |
| Deleting a secret | Kubernetes resource | deleteSecrets |
| Deleting a Service | Kubernetes resource | deleteServices |
| Deleting a StatefulSet | Kubernetes resource | deleteStatefulsets |
| Deleting a volume | Kubernetes resource | deleteVolumes |
| Replacing a ConfigMap | Kubernetes resource | updateConfigmaps |
| Replacing a DaemonSet | Kubernetes resource | updateDaemonsets |
| Replacing a Deployment | Kubernetes resource | updateDeployments |
| Replacing an event | Kubernetes resource | updateEvents |
| Replacing an ingress | Kubernetes resource | updateIngresses |
| Replacing a job | Kubernetes resource | updateJobs |
| Replacing a namespace | Kubernetes resource | updateNamespaces |
| Replacing a node | Kubernetes resource | updateNodes |
| Replacing a PersistentVolumeClaim | Kubernetes resource | updatePersistentvolumeclaims |
| Replacing a pod | Kubernetes resource | updatePods |
| Replacing a ReplicaSet | Kubernetes resource | updateReplicasets |
| Replacing a resource quota | Kubernetes resource | updateResourcequotas |
| Replacing a secret | Kubernetes resource | updateSecrets |
| Replacing a Service | Kubernetes resource | updateServices |
| Replacing a StatefulSet | Kubernetes resource | updateStatefulsets |
| Replacing a status | Kubernetes resource | updateStatus |
| Uploading a component chart | Kubernetes resource | uploadChart |
| Updating a component chart | Kubernetes resource | updateChart |
| Deleting a component chart | Kubernetes resource | deleteChart |
| Querying a component chart | Kubernetes resource | getChart |
| Creating a release | Kubernetes resource | createRelease |
| Updating a release | Kubernetes resource | updateRelease |
| Deleting a release | Kubernetes resource | deleteRelease |
| Querying a release | Kubernetes resource | getRelease |
| Backing up a cluster | Cluster | Snapshot |
| Querying the snapshot task list of a cluster | Cluster | GetSnapshotTasks |
| Synchronizing the node pool configuration to existing nodes | Cluster | SyncNodePool |
| Obtaining tenant permission application records | Cluster | ListPermissionApplyOrders |
| Applying for tenant permissions | Cluster | CreatePermissionApplyOrder |
| Adding resource tags to a cluster in a batch | Cluster | BatchCreateDeleteResourceTags |
| Deleting tags from a cluster in a batch | Cluster | BatchCreateDeleteResourceTags |
| Creating a partition | Cluster | CreatePartition |
| Querying a partition | Cluster | GetOnePartition |
| Querying the partition list of a cluster | Cluster | GetPartitionList |
| Updating a partition | Cluster | UpdatePartition |
| Querying a warm-up pool | Cluster | GetWarmUpPool |
| Querying the warm-up pool list | Cluster | ListWarmUpPool |
| Updating a warm-up pool | Cluster | UpdateWarmUpPool |
| Creating a warm-up pool | Cluster | CreateWarmUpPool |
| Deleting a warm-up pool | Cluster | DeleteWarmUpPool |
| Querying an upgrade path | Cluster | GetClusterUpgradePaths |
| Querying upgrade feature gates | Cluster | GetUpgradeFeatureGates |
| Obtaining an automatic upgrade plan | Cluster | GetUpgradePlans |
| Deleting an automatic upgrade plan | Cluster | DeleteUpgradePlan |
| Obtaining a cluster maintenance window | Cluster | GetMaintenanceWindow |
| Updating a cluster maintenance window | Cluster | UpdateMaintenanceWindow |
| Creating a cluster maintenance window | Cluster | CreateMaintenanceWindow |
| Deleting a cluster maintenance window | Cluster | DeleteMaintenanceWindow |
