- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
Managing kernel Options
CCE Autopilot is a serverless cluster and isolated from the kernel of physical machines. kernel tuning is a common practice in advanced service deployment scenarios. In a safe situation, CCE Autopilot allows you to configure kernel parameters through a security context of a pod based on the solution recommended by the Kubernetes community, greatly improving the flexibility of service deployment. For details of security contexts, see Configure a Security Context for a Pod or Container.
In Linux, sysctl is the most common method of modifying kernel parameters. In Kubernetes, kernel parameters are configured through the sysctl security context of the pod. If you are not familiar with the sysctl concept, see Using sysctls in a Kubernetes Cluster. A security context applies to all containers in the same pod.
CCE Autopilot allows you to modify the following non-secure sysctl parameters:
kernel.shm*, kernel.msg*, kernel.sem, fs.mqueue.*, net.*
To avoid affecting the stability of the OS, modify the sysctl parameters after understanding the consequences of the modification.
The sysctl parameters with a namespace may change in future Linux kernel versions.
Non-secure sysctl parameters are unstable. Using non-secure sysctl parameters may cause some serious problems, such as container errors. You need to take care of the risks.
In the following example, the pod's security context is used to set two sysctl parameters: kernel.msgmax and net.core.somaxconn.
apiVersion: v1 kind: Pod metadata: name: sysctls-context-example spec: securityContext: sysctls: - name: kernel.msgmax value: "65536" - name: net.core.somaxconn value: "1024" ...
Go to the container to check whether the configuration takes effect.
kubectl exec -it podname -c container-1 -- /bin/sh
