- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
SFS Turbo Volume Overview
Introduction
CCE Autopilot allows you to mount storage volumes created from SFS Turbo file systems and their subdirectories to a path of a container for persistent data storage. SFS Turbo file systems are fast, on-demand, and scalable, which are suitable for scenarios with a massive number of small files, such as DevOps, containerized microservices, and enterprise office applications.
Not all regions support SFS Turbo volumes. View the regions where SFS Turbo volumes are supported on the console. You can also view Function Overview to learn about all regions where these volumes are supported.
Expandable to 320 TB, SFS Turbo provides a fully hosted shared file storage, which is highly available and stable, to support small files and applications requiring low latency and high IOPS.
- Standard file protocols: You can mount file systems as volumes to servers, the same as using local directories.
- Data sharing: The same file system can be mounted to multiple servers, so that data can be shared.
- Private network: Users can access data only in private networks of data centers.
- Data isolation: The on-cloud storage service provides exclusive cloud file storage, which delivers data isolation and ensures IOPS performance.
- Use cases: Deployments and StatefulSets in the ReadWriteMany mode, and jobs created for high-traffic websites, log storage, DevOps, and enterprise OA applications
SFS Turbo Performance
For details about the performance parameters of SFS Turbo, see File System Types.
Application Scenarios
SFS Turbo supports the following mounting modes:
- Using an Existing SFS Turbo File System Through a Static PV: static provisioning. You use an existing file system to create a PV and then mount the PV to the workload through a PVC.
- (Recommended) Creating an SFS Turbo Subdirectory Using a Dynamic PV: CCE Autopilot allows you to create subdirectories for PVs that are dynamically provisioned from SFS Turbo file systems when creating PVCs and to configure the capacity of the subdirectories so that different workloads can share the PVs.
Billing
SFS Turbo does not support dynamic creation. Only created SFS Turbo volumes can be mounted. You can select the pay-per-use billing mode or yearly/monthly package as required. For pricing details about SFS Turbo, see Billing.
