- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
SFS Volume Overview
Introduction
CCE Autopilot allows you to mount a volume that is created from a Scalable File Service (SFS) file system to a container for persistent data storage. SFS volumes are commonly used in ReadWriteMany scenarios for large-capacity expansion and cost-sensitive services, such as media processing, content management, big data analysis, and workload analysis. For services with a massive number of small files, SFS Turbo file systems are recommended.
View the regions where SFS volumes are supported on the console. You can also view Function Overview to learn about all regions where SFS volumes are supported.
Expandable to petabytes, SFS provides fully hosted shared file storage, highly available and stable to handle data- and bandwidth-intensive applications
- Standard file protocols: You can mount file systems as volumes to servers, the same as using local directories.
- Data sharing: The same file system can be mounted to multiple servers, so that data can be shared.
- Private network: Users can access data only in private networks of data centers.
- Capacity and performance: The capacity of a single file system is high (PB level) and the performance is excellent (ms-level read/write I/O latency).
- Use cases: Deployments and StatefulSets in the ReadWriteMany mode, and jobs created for high-performance computing (HPC), media processing, content management, web services, big data analysis, and workload process analysis
Performance
SFS provides two types of file systems: General Purpose File System (formerly SFS 3.0) and SFS Capacity-Oriented. CCE Autopilot clusters support only General Purpose File System (formerly SFS 3.0). For details about the performance of General Purpose File System, see File System Types.
Parameter |
General Purpose File System (formerly SFS 3.0) |
Maximum bandwidth |
1.25 TB/s |
Maximum IOPS |
Million |
Latency |
10 ms |
Maximum capacity |
EB |
Application Scenarios
SFS supports the following mounting modes based on application scenarios:
- Using an Existing File System Through a Static PV: static provisioning. You use an existing file system to create a PV and then mount the PV to the workload through a PVC. This mode applies to scenarios where the underlying storage is available or billed on a yearly/monthly basis.
- Using an SFS File System Through a Dynamic PV: dynamic provisioning. You do not need to create volumes in advance. Instead, you need to specify a StorageClass during PVC creation. A file system and a PV will be automatically created. This mode applies to scenarios where no underlying storage is available.
Billing
- For SFS volumes automatically created using StorageClass, the default billing mode is Pay-per-use. You are billed based on the storage capacity and duration. For SFS pricing details, see Billing.
- If you want to be billed on a yearly/monthly basis, use existing SFS volumes.
