Cloud Native Log Collection
Updated on 2025-02-27 GMT+08:00
Introduction
The Cloud Native Log Collection add-on (log-agent) is developed based on Fluent Bit and OpenTelemetry for collecting logs and Kubernetes events. After the add-on is installed, the fluent-bit container component is automatically created for log collection. This add-on supports CRD-based log collection policies. It collects and forwards standard output logs, container file logs, and Kubernetes event logs in a cluster based on configured policies. It also reports all abnormal Kubernetes events and some normal Kubernetes events to AOM. For details about how to collect logs, see Collecting Logs.
The fluent-bit container component is provided by Huawei Cloud for free.
The constraints on using the log-agent add-on are as follows:
  • A maximum of 50 log collection rules can be configured for each cluster.
  • log-agent cannot collect .gz, .tar, or .zip log files.
  • If the container runtime is containerd, stdout logs cannot be multi-line.
  • In each cluster, up to 10,000 single-line logs can be collected per second, and up to 2,000 multi-line logs can be collected per second.
Permissions
The fluent-bit component reads and collects the standard output logs and container file logs based on the collection configuration.
The following permissions are required for running the fluent-bit component:
  • CAP_DAC_OVERRIDE: ignores the discretionary access control (DAC) restrictions on files.
  • CAP_FOWNER: ignores the restrictions that the file owner ID must match the process user ID.
  • DAC_READ_SEARCH: ignores the DAC restrictions on file reading and catalog research.
  • SYS_PTRACE: allows all processes to be traced.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons. Locate Cloud Native Log Collection on the right and click Install.
  2. On the Install Add-on page, configure the specifications.
    Table 1 Add-on specifications
    Pods
    Number of pods that will be created to match the selected add-on specifications.
    If you select Custom, you can adjust the number of pods as required.
    The add-on contains the following container components, whose specifications can be adjusted as required:
    • log-operator: parses and updates log rules.
    • otel-collector: forwards logs collected by fluent-bit to LTS.
  3. Click Install.
Components
Table 2 log-agent components
Component
Resource Type
fluent-bit
A lightweight log collector and forwarder for collecting logs.
Pod
log-operator
Used to generate internal configuration files
Deployment
otel-collector
Used to collect logs from applications and services and report the logs to LTS
Deployment
