Configuring Security Group Rules for ICMP Traffic
Dedicated load balancers are used for CCE Autopilot clusters. If both the listener protocol and the health check protocol are UDP, you need to allow ICMP traffic from the backend subnet of the load balancer in the security group associated with the elastic network interfaces.
- On the CCE console, click the cluster name to access the Overview page of the cluster console.
- In the Networking Configuration area on the right, click the VPC name. In the navigation pane of Network Console, choose Access Control > Security Groups.
- In the security group list, locate the security group associated with the elastic network interfaces. The default security group is named {Cluster name}-cce-eni-{Random ID}.
If you specify a custom security group for the cluster, select this security group.
- Click the name of the security group. On the Inbound Rules tab, click Add Rule to add an inbound rule. For details, see Figure 1.
- Protocol & Port: Select all ICMP ports.
- Source: Enter the backend subnet of the load balancer.
- Click OK.
