Help Center/
Cloud Connect/
User Guide/
Cloud Connection Operation Guide/
Bandwidth Packages/
Bandwidth Package Overview
Updated on 2025-04-16 GMT+08:00
What Is a Bandwidth Package?
- A bandwidth package is required for inter-region communication regardless of whether:
- The two regions are within the same geographic region.
- The two regions are in different geographic regions.
- Bandwidth packages are not required for communication among network instances in the same region.
Constraints on Bandwidth Packages
- A bandwidth package can only be bound to one cloud connection.
- A cloud connection can only have one bandwidth package bound if the geographic region and billing mode of the bandwidth packages are the same.
- No bandwidth packages are required if two VPCs are in the same region because they can communicate with each other by default after they are loaded to the same cloud connection.
- The geographic regions of a bandwidth package cannot be changed after it is purchased.
Parent topic: Bandwidth Packages
