Help Center/Cloud Connect/User Guide/Cloud Connection Operation Guide/Network Instances/Network Instance Overview
Updated on 2026-03-06 GMT+08:00
What Is a Network Instance?
A network instance can be a VPC or virtual gateway.
- VPCs can be connected using a cloud connection.
- If VPCs are connected by a cloud connection, virtual gateways associated with each VPC can be loaded to this cloud connection to allow the on-premises data center to communicate with these VPCs.
In Direct Connect, a virtual gateway associates a virtual interface with a VPC so that the on-premises data center can access this VPC. For more information about Direct Connect, see What Is Direct Connect?
Figure 1 How Direct Connect works
Constraints on Network Instances
- If network instances are in the same region, they can communicate with each other by default after they are loaded to a cloud connection.
- If network instances are in different regions, purchase a bandwidth package and assign inter-region bandwidths. For details, see Buying a Bandwidth Package and Assigning an Inter-Region Bandwidth.
- You can only load one network instance to a cloud connection.
- If a VPC is loaded, the associated virtual gateway cannot be loaded.
- To load a network instance in another account, you must ask that account to grant you the permission to load the network instance to your cloud connection.
- Loading 100.64.0.0/10 to a cloud connection may cause services such as OBS, DNS, and API Gateway to become unavailable.
Parent topic:Network Instances
