Help Center/
Cloud Connect/
User Guide/
Central Network Operation Guide/
Global Connection Bandwidths/
Adding Instances to a Global Connection Bandwidth
Updated on 2025-04-16 GMT+08:00
Add a cloud service instance (global EIP or central network) to a global connection bandwidth.
- Instances that can be added to a global connection bandwidth must be from the same region as the bandwidth.
- A global connection bandwidth can only be used by instances of the same type. If you want another type of instances to use a global connection bandwidth that already has instances, you need to remove the instances first.
- You can add or remove global EIPs in batches.
- You can bind one global connection bandwidth to or unbind it from a central network at a time.
- To use a global connection bandwidth on a central network, you need to configure cross-site connections by referring to the following:
- Global connection bandwidths of different types can be used with different instances. For details, see Table 1.
Using a Global Connection Bandwidth on a Central Network
- Go to the Central Networks page.
- Locate the central network and click its name.
- Click the Cross-Site Connection Bandwidths tab.
- Locate the cross-site connection and click Assign in the Global Connection Bandwidth column.
- On the Assign Cross-Site Connection Bandwidth page, select the global connection bandwidth.
- Specify the bandwidth and click OK.
Adding Global EIPs to a Global Connection Bandwidth
- Go to the Global Connection Bandwidths page.
- Locate the global connection bandwidth and click Bind in the Operation column.
- In the displayed dialog box, select Global EIP for Instance Type.
For a multi-city global connection bandwidth, select the two regions where the bandwidth will be used.
- Search for global EIPs using keyword.
- Select one or more global EIPs and click OK.
Parent topic: Global Connection Bandwidths
