Buying a Global Connection Bandwidth
This section describes how to buy a global connection bandwidth for communication over the backbone network.
- Go to the Create Global Connection Bandwidth page.
- Configure the parameters based on Table 1.
Table 1 Parameters required for buying a global connection bandwidth Parameter
Setting
Example Value
Billing Mode
Mandatory
Pay-per-use: a postpaid subscription. You are charged based on the usage duration of the global connection bandwidth. The usage of a global connection bandwidth is calculated by the second but billed by hour. If the usage is less than an hour, you are billed based on the actual duration.
Pay-per-use
Bandwidth Type
Mandatory
Select a bandwidth type. There are different types of global connection bandwidths that are designed for different application scenarios, including multi-city, geographic-region, and cross-geographic-region bandwidths. The type of a bandwidth cannot be changed once it is created.
For details, see Global Connection Bandwidth Overview.
You can decide whether to use a geographic-region bandwidth or cross-geographic-region bandwidth based on service scenarios.
If you select a geographic-region, cross-geographic-region, or HomeZones bandwidth, you also need to select geographic regions and specify the regions that need to communicate with each other.
Geographic-region
Billed By
Mandatory
The price of a global connection bandwidth varies by its size.
- After a bandwidth is purchased, the billing starts immediately regardless of whether the bandwidth is used.
- If a bandwidth is no longer required, delete it in a timely manner to avoid unnecessary fees.
Bandwidth
Bandwidth
Mandatory
Select the bandwidth, in Mbit/s.
100
Bandwidth Name
Mandatory
Enter the name of the bandwidth. The name:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
bandwidth-test
Enterprise Project
Mandatory
Provides a cloud resource management mode, in which cloud resources and members are centrally managed by project.
default
- Click Next.
- Confirm the configurations and click Submit.
The global connection bandwidth list page is displayed.
- In the global connection bandwidth list, view the status of the bandwidth.
If the bandwidth status becomes Normal, the purchase is successful.
